How do you shut off the hazard lights on an Eagle Vision?
dangerusdug
Member Posts: 2
Eagle Vision, hazard lights won't shut off at the switch.
Best Answer
OptionsMr_Shiftright Member Posts: 64,481You might pop out the switch and test it with an ohm meter to see if it's remaining open. I guess you could temporarily pull fuse F1 in the power distribution box but I can't tell if that will also disable other functions---it might. Also keep in mind that the flasher circuit is wired through your multi-function headlight switch, so there's another possibility of some wiring or connection issue.5
Answers
