Buick LeSabre bad knocking noise coming from the engine.
Have a 2005 Lasabre 3.8. Had a bad knocking noise coming from the engine. Took off the belt and started it up no more noise. Replaced the harmonic balancer still have the noise with the belt on.
Noise goes away if you run the engine at a higher rpm . Car has only 62,000 miles. Not losing any antifreeze or oil. A/c doesn't work. Has plenty of heat. Noise is so loud can't figure out where it is coming from. Can anyone help?
Answers
water pump
power steering pump
alternator
AC compressor pulley unless the compressor is engaged (test by turning HVAC off on the dash)
idler pulley on the tensioner (pulley and its bearing can be replaced without replacing the tensioner--bolt is reverse threaded)
Maybe a bad belt? You should be able to visually see a flaw on the grooved side.
You can rotate each of the devices when you have that belt off and check for wobble, in-and-out play, and a roughness coming as you turn the pulley on each.
Have you tried a mechanics stethoscope device? Make one using a short broom stick size of wood that you hold against each of the potential items _carefully_ with the engine making the noise and hold the other end to your ear.
Good luck. Please let me know what you do find. I am curious. Too often the knock is internal and that's bad news.
Can you buy or borrow a mechanic's stethoscope? Not very expensive---just a long rod attached to some tubing and simple set of earphones. Naturally doing this with a spinning engine requires a great deal of caution, no loose clothing, good eye protection, etc.
Here's a video that shows you:
https://www.youtube.com/watch?v=KMIHDfnQ9hs
Do the local box stores like Autozone or OReilly have those in their loaner parts?
The AC compressor pulley has a bearing as well.That pulley could be making noise even though the clutch is not engaged. Also check around the transmission to engine connection--I don't know if it's relevant here but some people have had knocking sounds with a plate that is part of the torque converter connection to the engine.
As to the water pump, you should have been able to feel something in the pulley and axle for it while the belt was off when you tested each of the accessories. Did you test the idler puller on the tensioner?
I would stop replacing parts until you can isolate the location. You may need to pay a good mechanic shop with an expert in this for some time for him to listen to the engine with a stethoscope. That might save you in the end.
$3.99 at harbor freight stores, if you're in an area where they have one.
harborfreight.com
http://www.harborfreight.com/mechanics-stethoscope-69913.html
Also i hope and pray that whoever replaced the crank pulley took a good long look at the pulley keyway and the slot on the crankshaft nub.
Either way, you REALLY need to be careful when doing this.
I once saw the aftermath of a long haired VW mechanic getting his hair in the spinning
generator pulley. I'll skip the description but it wasn't a good thing.
Said it could be a rod bearing so I dropped the oil pan. Didn't find any metal in the bottom of the pan all the rods are tight from what I could tell. Moved the crank back and forth to see if there was any play in the rods none that I could see. Said it wouldn't be a lifter because the knocking was to low in the engine. May just have to take it to a garage to see if they can figure it out.
Read that some of these engines 3.8 series 2 develop what they call piston slap. Anyone heard of this or dealt with it. I had changed the oil that's when the knocking got louder and when I drained the oil to take the pan off the oil seemed to me to be pretty dark already since I had only put less than 200 miles on. No gas smell in the oil or milky substance. Any more ideas of what it could be? Thanks
This is one of the problems with noises, nothing compares to hearing it first hand and investigating from there. With the location now changed from your original description I wouldn't rule out a broken flexplate. Some of the other thigs i have found through the years are camshaft bearings. These can develop a thrusting of the camshaft behind the timing cover and that causes a pretty good knock if they are too loose. Another potential noise is caused by wear in the balance shaft bearings.
I had read a few stories in Pontiacs where noises were traced to the plate.
It's possible a main bearing could knock at idle but that is a VERY deep, dull sound. Did anyone try to pry the crankshaft forward and back?
You can check for a wrist pin noise pretty easily--if you disconnect or short out the spark plug to the suspect cylinder, the noise will double in frequency, from TAP to TAP-TAP, once you disconnect the spark plug.
Piston slap will generally go away once the engine is warm. It's a cold engine symptom. You can test for piston slap by removing the spark plug and squirting an ounce or two of oil in the cylinder. They re-insert the plug, and if there was piston slap, it will disappear for 30 seconds or so and then return as usual.
Another thing you can do is remove your oil filter and cut it open and look for metallic debris.
If there is none, you should probably move onto the flex plate.
After you've already replaced PS pump, I'd really hate to see the flex plate be a wrong diagnosis and have you R&R on it.
this suggests to me that the source of the noise is related to vibration at rest rather than stress.
