Honda CR-V barely starts when temp drops
 cherokeekb23
                    Member Posts: 1
cherokeekb23
                    Member Posts: 1
                    I have a 2003 Honda CRV that has a hard time turning over when the temperature drops slightly. We've replaced the battery and the spark plugs already but there's no difference. Once the vehicle has warmed up, it starts just fine -- when it's warm outside, it starts just fine. Today, the temperature was barely below freezing and after it sat outside for 8 hours, it didn't start on the first attempt. It was slow to turn over and after a few usuccessful turn overs, it quit trying. I turned the key off and tried again -- this time it turned a little faster and eventually started once I gave it a little gas while turning the key. Could the starter be wearing out or is there something else we need to check?
Answers
First thing my mind goes to is cranking capacity of the battery, but given the temperature you're talking about, that doesn't seem like it would be an issue. So what else could make it difficult for an engine to turn over. Friction. Check the oil level perhaps? Since the car is starting OK and running OK when warmer, I assume it's not without oil. Just flailing a bit for an idea here
Just because it isn't very old doesn't mean it's not up to snuff. A load test will tell you what's up.
when it gets cold, a battery can lose 30% or more of its efficiency. So if it's a bit run down to begin with, freezing temps will finish it off.
What kind of oil do you have in there?
