There is nothing "easy" about using an easy out especially when the bolt is broken off at an angle and you can't get a drill bit to dig in!
This becomes almost a theological question: "What type of easy out can drill out an easy out?"
Nothing an acetylene torch can't deal with!
"Hello, Headquarters? This is Captain Shiftright. I have new coordinates for your heaviest artillery!"
Believe me after my 20 years in the tool business, I've seen EVERYTHING get broken!
It was always the fault of the tool though, doncha know?
I may have known the guy who sold it to you.
I once saw the aftermath of a brand new Snap On Mega Box that got bumped by a car into an alignment pit! The drawers were open so you can imagine. The guy who did it was it's proud new owner!
Watch the whole video.
https://www.youtube.com/watch?v=kKdKC4KGKEE
Taps and "easy" outs burn out just fine in cast iron, but that doesn't work in aluminum. These drill bits do work.
Patience is often the key to nut-busting. A 4-foot lever is not patient
Set me on by rear at the same time. Ouch!
Does anyone else find it really annoying after three days and two nights of fussing with liquid wrench, this tool,that tool and then having the thing free up in about 1/10 of a second and being able to remove with just finger pressure as soon as it does?
For motorcycles, I used to tease my Harley friends with "The Harley Company Motto" -- "if it breaks, make it bigger; if it sticks out too far, chrome it".
In addition to Murphy's law, I had another personal DIYer's motto: "Disassembly occurs at 8 times the rate of reassembly".
Rusted exhaust manifold bolts can be NASTY!
2. There are tools that allow us to use the air hammer while a fastener is being turned when heating is inappropriate. Bleeder screws are an example. By vibrating the caliper with a hammer head the screw comes loose easily.
"By streaming data from sensors in the car up into Chevy's cloud, GM says it'll be able to proactively detect when certain parts of the car are prone to failure using "proprietary algorithms," which means you could potentially get the car into a dealership before you have a real problem out on the road. Right now, there are only three parts covered under the system — the battery, the starter motor, and the fuel pump — but more parts are expected to be added into the program in future vehicles."
New Chevrolet cars will predict when their parts are going to fail (theverge.com)
Mine: 1995 318ti Club Sport-2020 C43-2021 Sahara 4xe-1996 Speed Triple Challenge Cup Replica
Wife's: 2015 X1 xDrive28i
"I'm sorry Dave. I can't let you do that".
The ECU has not stored any further catalyst efficiency faults since the Cataclean treatment over 12 months and 10,000 miles ago.
So I'd have to say it would be worth a try...
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2458795#Post2458795
The MSDS of Cataclean.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CB4QFjAA&url=http://apkgroup.com/msds/English/CAC%20-%20Cataclean%20Chemicals/120007%2805-01-2010%29.pdf&ei=kp2uVPztConnsATT84CoCA&usg=AFQjCNHYH_vQeXlx7f-Y7xm0WeCFGhBHBg&sig2=bQITHpi83NZOvqNAMvOpPg&bvm=bv.83134100,d.cWc
Boy, do I feel silly...
The Bob is the Oil Guy link is quite helpful however, I'm sure several folks will find the last post in the thread to be a lifesaver!!!
http://www.asrcreviews.org/2014/03/nad-recommends-accel-discontinue-challenged-claims-for-cataclean-fuel-additive/
http://www.asa.org.uk/Rulings/Adjudications/2006/7/Best-Direct/TF_ADJ_41571.aspx#.U6mDhrE1Ocw
Does anyone have any experience with a car that threw multiple catalyst efficiency codes that suddenly "cured" itself?
How did that happen?
As I understand it, catalyst efficiency only has to be down 5% to trigger that fault, so I perhaps the effectiveness of Cataclean depends in large part on how degraded the cats are.to begin with.
Try a gallon in the Wrangler. Rinse and repeat.
There are hundreds of papers like this one has to read to fully understand exactly what a catalyst does and how a catalyst ages.
http://www.academia.edu/2712048/On-board_diagnosis_of_SI_engine_catalyst_efficiency_a_confidence_level_analysis
If I say--but there's no evidence that mushrooms cure the flu, they say "But I feel better. It worked!"
I can't say if it worked or not because, as Steve said, there are no controls on the experiment.
Maybe the catalytic was revived by the juice, or maybe the additive just cleaned up a spark plug, or maybe the car just fixed itself (it happens). I recently watched a YouTube video where a guy's engine is running rough, and not able to pass smog---so then he adds the Cataclean, drives 75 miles and suddenly his engine runs smoother and he passes smog.
Well, what really happened here?
If the CEL came on a few hundred miles after the smog test, I'd be inclined to give credit to the additive. The fact that the CEL never came on again makes me wonder about the additive as the cause.
I KNEW you'd bite on that one...
I don't know why I bothered bringing this up, I should have just paid a "professional technician" to R&R the cats. I'd be $1,800 poorer, but at least the "Professional Technician" would be having a prosperous new year.
Your cat's chemistry may have been thirsty for a shot of acetone. But mine may just ignore the fumes. (hm, maybe for the search engines I'd should spell out catalytic).
Or maybe you hit a bump just right driving over to get the codes rechecked.
I'm not so convinced about Techron anymore either. That really gets back to the seat of your pants testing.
Can't wait till I get an EV so I can complain that it's sluggish running coal power but really zooms when the electricity comes from my windmill.
This would actually be a good seat of the pants place to test Techron if I still had my Quest. It usually got Chevron during the Boise decade and a bottle once or twice a year in the UP. No Chevron here, and I'm buying a lot of cheap gas (usually Murphy). But no Quest either anymore. It's on sale at Advance btw for like half price.
It took me years to wean my wife off HEET - she thought that cured any car hiccup back in the pre-ethanol days. Now with E-10 everywhere, she actually won that argument.
One H3LL of a placebo...
This has been fun. Got any Dexos stories?
Guinness World Records.....are you listening?
No 4X4 light since- but I'm certain some dealers and shops would have told me "YOUR STEERING ANGLE SENSOR IS GOING BAD!!! IF YOU DON'T FIX IT IMMEDIATELY YOU COULD DIE!!!
I had my MINI cat go bad but unfortunately nothing in a can could fix it, as it just fell to pieces internally. Were it not for creative thinking, I would have been skunked for $1800 bucks.
I have to say, I hope BMW has upped their quality control for the MINI over the last 10 years, because it has been disgraceful on the early cars.
