Rear passenger wheel stuck
rod65rod65 Member Posts: 2
edited January 2015 in Kia
Hi! I have 05 kia sportage v6 and the rear wheel passenger side is locked up, won't turn. Pls give me an advice.
  • rod65rod65 Member Posts: 2
    I bleed the brake but still locked up.
    You might check the parking brake cable and see if it is binding.
  • thecardoc3thecardoc3 Member Posts: 5,842
    If the parking brake cable has frozen and that is holding the wheel, the first thing you can try is to manipulate the cable housing and you might get it to release. If the parking brake actuator lever is accessible it may be possible to take a punch and tap it back to the released position. If that doesn't work we use a pair of bolt cutters to cut the cable as close to the wheel as possible. This problem can be very difficult to deal with until it is disassembled. Then its just a matter of getting the parts to put it all back together.
