What's the fix for the heat situation?
also my ac blow cold on driver side and hot on the passenger side?
help me please
Best,
Sarah
GM Customer Service
The dealer took the unit in and couldn't figure out why this was happening. Later in the day, they called and said this was NORMAL as it was an upgrade in the programming of the AC system which would keep the AC fan on (in low speed) after the unit was shut down to reduce humidity in the system.
Anyone heard of this before or have seen this happen?
Do you believe the dealer's explanation?
I'm very concerned this would drain my battery or ever worse cause an electrical fire while I'm away.
Oh and the gas tank piece didn't even fix the gague now they are saying it is my instrument panel and that is $400.00 so I am just keeping track of my miles and that is a pain!!!
How do I get to it and how do I replace it??
The ticking lasts for about 2 minutes then stops. Drives us nuts!!!
Nancy
Any input would be appreciated, Tim
