06 Hyundai Tuscon. No spark or fuel pump kicking on.
nitsud880nitsud880 Member Posts: 3
edited January 2015 in Hyundai
No spark and fule pump isnt kicking on had this issue once had to have the dealership fix. Ended up being main starter fuse. The said it was in thefuse box inside csr box looke all over no luck all good. Called again the said its the one on the positive battery terminal. 140 amp male bolt in. Cant find any info on this or a replacement one. Not sure if tht fuse will even fix the issue. Any info greatly appreciated
Answers
  • nitsud880nitsud880 Member Posts: 3
    Update. Rechecked al fuses. Replaced some relays. And the fuseable link that was on the battery still no spark or fule pump power. On its way to the dealer tomorrow or friday
    Final update wiring harness for main relay went bad install and labor 550
  • kyfdxkyfdx Moderator Posts: 269,150
    Thanks for letting us know. Too bad it wasn't something cheaper. Wishing you good luck with your Tuscon in the future.
