2003 LeSabre Ignition Module
major601major601 Member Posts: 2
edited January 2015 in Buick
I've had to replace the Ignition Module 5 times in the past 7 months. They suggested the coil pack was making it too hot after number 3, so I let em replace that. No joy, 2 ICM later. Of course, now they're not wanting to warranty any more failures, so my question is this: what could be causing the ICM to fail?
Answers
  • imidazol97imidazol97 Member Posts: 27,758
    edited January 2015
    Were the failed Ignition Spark Control Modules all the same brand?
    Is it the correct part number?
    Look it up in this list:
    AIRTEX / WELLS Part # 2C7 $74.79
    STANDARD MOTOR PRODUCTS Part # LX364T T-Series $99.89
    UNITED IGNITION WIRE Part # DCM9607 106.79
    DELPHI Part # DS1004 $125.79
    STANDARD MOTOR PRODUCTS Part # LX364 $132.89
    AIRTEX / WELLS Part # 6H1045 $135.79
    ACDELCO Part # D1977A
    {#10494012, 12617924, 19245558} GM Original Equipment
    MODULE,IGN COIL $170.7
    Is silicon dielectric grease needed where the ICM is screwed down to the engine
    part to transfer heat? Is the engine part there clean of corrosion?
    There are 3 coils on the car--they only replaced one?
