2016 Mazda MX-5 Miata U.S. Engine Specs Released | Edmunds.com
edited February 2015 in Mazda
image2016 Mazda MX-5 Miata U.S. Engine Specs Released | Edmunds.com
Car shoppers received a critical piece of information about the 2016 Mazda MX-5 Miata convertible late last week as Mazda confirmed U.S. engine specifications.
    Shedding 150lbs is good, shedding 12 hp, not so much. The 2.5 SA wouldn't fit? The Miata doesn't need 200 hp, but the extra 30 from the 2.5 would be welcome.
  • 7driver7driver Member Posts: 145
    Interesting. It has the same HP as the SkyActiv 2.0l from the CX-5 and Mazda3 but loses 2lb-ft of TQ from those two installations. I wonder if Mazda had trouble fitting the trick Skyactiv exhaust headers in the smaller Miata?
  • desmoliciousdesmolicious Member Posts: 671
    I'm thinking that in a year or so the turbo model is going to be released. I'll wait for that.
  • actualsizeactualsize Member Posts: 451
    Because the ND is lighter, it's power to weight ratio is equal to that of the NC despite 12 fewer horsepower. But the lighter ND does have 8 more lb-ft of torque than the NC, so it should pull stronger out of the hole.
    Twitter: @Edmunds_Test
  • kyolmlkyolml Member Posts: 37
    the NC MZR engine makes more power than the Mazda 3 equivalent. When they introduced the skyactiv Mazda 3 it has more power than the MZR. Now the skyactiv Miata doesn't, it's just they being plain lazy. At lease give us the 167 as the MZR. With direct injection, they have no reason not too
  • tommygnrtommygnr Member Posts: 1
    2300 pound car needs 230hp in this day and age.
