Car shuts down while driving - '07 Pacifica
I bought my car in August last year, it's a Chrysler Pacifica 2007. For the first few months it was great, then about in October as I was driving, it just shut down like I had turned off the ignition. It has done this several times and it scares me, it always cranks right back up but it should not shut down in the first place. I can't find any recalls for it and it's been at the dealer's where I bought it but they have no idea what is going on with it. Can someone please help or at least give me an idea what the problem is?
Some of the other details that I would need are, how likely is an even to occur if the car was driven for a given distance or time? Does the problem occur when driving on the highway, when coming to a stop or anytime at all?
Is there anything else that also stops working? (Power windows, radio, heater???)
Armed with the above information now the car has to be driven and the technician experience the problem while the test equipment is connected to the car. As each occurrence of the event is caught and the data analyzed, then the testing points would be changed until the tech arrives at a solution.
In the ideal situation, test equipment would be hooked up as the car fails.
Intermittent problems can be a devil, because when they aren't happening, they aren't there. Not every component or module will throw a trouble code.
