Have you recently purchased a new car or are you trying to and struggling to find affordable options? A reporter would like to speak with you; please reach out to [email protected] by 5/26 for more details.
Dodge Durango overheated and had foam coming out
my 2000 dodge dorango over heated and had foam coming out of the over flow why did it do that what causes it
Also maybe it's just years of gunk in there that clogged the radiator. Probably you need to have the radiator cleaned out thoroughly and the thermostat check and if that doesn't cure the overheat you should have the new coolant tested for presence of combustion gases.
