Problems after installing aftermarket radio
After finishing installing my aftermarket radio, I discovered that my windshield wipers, dashlights, rear defrost, dash info display, and the gas gauge do not work. I used the metra install kit for the radio and the radio works fine exvept it does not turn on in the accessory position of the key. Does anybody have any suggestions that I can try or have a wiring diagram for the wiring harness in the audio system?
Do you have your wipers and gauges back?
I do not have the wipers and gauges back stever.
Fuse 22 was blown. Changed it and everything works perfectly now! Radio sounds so much better than the factory radio. Thank you again!
