Vibration issue with 2015 Honda CR-V
                    All,
There is A BIG issue with vibration with new Honda CRV 2015. The issue kills new car experience. I am even worried that we are stuck with the issue. When you stop at stop light and car is in drive you will notice vibration and it will continue until you drive again. This is very noticeable even in the back seat! I hope there is fix for it. Everyone who has bought the car (including me) has complained about it.
See Also
2015 Honda CR-V Consumer Reviews
See Also
1
Unfortunately "adjustments" can only be made by changes in the software at the engineering level and then get passed onto the dealers service department so that the dealers technicians can re-flash the engine controller. Sometimes, they have to identify a problem like you describe and then re-write the soft wear to fix it and that can take some time because they also have to certify that the software update doesn't make the car pollute the air.
It may be annoying, but give them some time and you will probably see them get a TSB addressing the issue.
i have same problem only drive 230 miles.
i'll take to the dealer.
This is keeping me from buying a CR-V at this time. I can't believe that Honda makes all these great improvements and lets this problem slide by. Disgraceful!
One thing that's not clear is if this problem shows up on ALL cars.
I've looked at many test drive videos (not dealer videos) and reviews, some of them have had the car for a week, and not one of them have mentioned this problem.
Doesn't make sense.
Please post and let us know if you have not had this problem.
How Can a Technical Service Bulletin Help Me?
We have summaries here too on the Edmunds Car Maintenance Guide.
Another good resource is bbbind.com. You have to register (free) but it's easy.
It's too early I think for a vibration "fix" to get issued, unless Honda is just doing something on a case by case basis as people complain. So it would pay to make a service appointment and get your CR-V checked and get your complaint in the database.
I visited 3 dealerships, and test drove 3 CR-Vs.
#1 dealership...supposedly ALL their CR-Vs shake...and they don't give a ....That includes the sales and service.
#2 and #3 CR-Vs drove with NO vibration.
I checked them out identically.
I warmed them up. Drove reg and highway. Stopped in D, shut everything off.
Here's what I found:
The ones that vibrate are the ones with RPM dipping below 600 (at the one dealer).
The ones that didn't vibrate, their RPM NEVER dropped below 750 when everything was shut off, in D , and warmed up.
Seems to me that the RPM is adjusted willy nilly at Honda!!!!
I am guessing that there are many vibrating CRVs but people drive with lights, heat, radio, on and that brings the rpm to above 600. They may not know that their CRVs vibrate.
It seems that there are others who have MORE issues with their Hondas than just plain vibration.
I like the CRV, but am a bit apprehensive to buy one.
I cannot believe that Honda wouldn't do anything about it...?
ez_dayz,
Just curious about the RPM. If you are in D, the CRV warmed up, everything off....what is the RPM reading on your vehicle?
NUMBER OF OPEN RECALLS: 1
LAST UPDATED: Mar 03, 2015
NHTSA RECALL NUMBER: AWAITING#
MFR CAMPAIGN ID: JP3
RECALL DATE: 02/26/2015
RECALL STATUS: Recall INCOMPLETE. Remedy not yet available.
SUMMARY:
AMERICAN HONDA MOTOR CO., INC. (HONDA) IS RECALLING CERTAIN MODEL YEAR 2015 HONDA CR-V VEHICLES. DURING ASSEMBLY OF THE SHORT BLOCK, IT IS POSSIBLE THAT NOT ALL OF THE CONNECTING ROD BOLTS WERE TORQUED TO THE SPECIFICATION.
SAFETY RISK:
IF A CONNECTING ROD BOLT WAS NOT TORQUED CORRECTLY, THE ENGINE MAY RATTLE/KNOCK, LEAK OIL, OR LOSE POWER, INCREASING THE RISK OF A CRASH.
REMEDY:
HONDA WILL NOTIFY OWNERS, AND DEALERS WILL REPLACE THE ENGINE SHORT BLOCK, FREE OF CHARGE. NOTIFICATION TO CUSTOMERS ABOUT THIS RECALL IS EXPECTED TO BEGIN MARCH 27, 2015. OWNERS MAY CONTACT THE HONDA AUTOMOBILE CUSTOMER SERVICE AT 888-234-2138. HONDA'S CAMPAIGN NUMBER FOR THIS RECALL IS JP2.
I called regarding this and asked if the vibration is a part of it. The person thought that it may but she wasn't 100% certain because this issue is still not complete. Honda is gathering VIN#s, and information. I asked if she heard about the vibration. She said that she did ....and she could see how the part where it says "the engine may rattle..." could entail the vibration.
Nonetheless, this recall seems to be in its early stages. She told me that Honda stopped the sale of the CRVs with most of the VIN #'s that seem to be affected....I guess there may be more to come....?
Point being that Honda is still collecting VIN #s and call-in issues.
I don't know which of the CRVs RPM were improperly set....the ones that dipped below 600, or the ones that never dipped below 750 , warmed up, at rest in D, with everything off.
I would like to see more people posting one way or another. My sample was small.
Besides, the person at the 888-234-2138 number was aware of the vibration, and didn't say that it was normal. She wasn't sure though if any of the vibrating CRVs were included in this up coming recall, because Honda is STILL taking Vin#s, and complaints. Supposedly, Honda stopped the sale of the VIN #s that they know have problems...She had a longer list of issues in front of her. She was reading it and couldn't tell for certain. All this is still incomplete.
http://en.wikipedia.org/wiki/Desaxe
Who remembers the Hudson Hornet?
http://speedtalk.com/forum/viewtopic.php?p=25511
If the vibration being sensed is from the crankshaft offset then some of the complaints are based more on a change in what people want to tolerate as compared to what is actually there. Speedometer cables went through the same kind of a situation. At one time noise from the cables was only a concern if they got really loud, but as the cars got quieter what was actually normal eventually became intolerable and so electronic speedometers went from being a top end luxury to a standard across the industry.
Maybe a partial fix for Honda (next time...) would be adding start/stop technology.
Start/stop cuts off and the engine will turn on when you are running the AC and stuff at idle and the battery decides it needs some juice, I think.
-The Rav4 drove very nicely, but I'm not a fan of its' interior. I couldn't get past the aesthetics. I understand it's subjective.
-The Rogue had a SLIGHT VIBRATION to it. I felt the massage while driving and sitting on lights. I came to the conclusion that it's the CVT, because that's the thing that Rogue has in common with the CRV.
-Perhaps the Honda just needs a slight adjustment to minimize the vibration?
The need for the system to have the engine running or not and the strategies involved and the diagnostic routines that would have to be followed can take some forty hours of classroom time to cover, and that's if you only concentrate on the most popular models.
1) Updated technology features (love the blind spot camera on the passenger side), 2) better fuel economy of the Honda, and 3) like the dashboard layout much better than the Toyo. I did like the Toyo 6 speed tranny, but it did shift a huge amount, especially in economy mode, even going up very slight grades at freeway speeds. I finally decided that putting up with some vibration at idle was a worthwhile trade-off to gain 3-4 MGP, and to get a nicer ride. The Toyo Limited RAV4 had a virtually punishing ride, and thumped and shuddered constantly (probably due to 18 inch wheels and low aspect ratio tires). I am 62 years old, and decided I did not want to go back to stiff "sport" suspensions. I will keep everybody posted on my experiences with the CRV. There are only 89 miles on this car, so cannot speak to specifics right not. The display in the dash, and the menu option capability (along with personally programming various parameters) simply blows Toyota away. If technology is important to you, there is no contest between Honda and Toyota regarding RAV4 vs. CRV.
I would love to have test driven a Subaru, but no dealer around here. I am DONE with having to hassle with dealerships in remote locations. Nothing but hassles. GLTA CRV owners. I am now one of them...for good OR bad. BTW...I also bought a 36 month top-to-bottom extended warranty (cost was $ 1145). I decided to do so given that 1) I tend to keep cars 10 years or longer, and 2) this CRV has a new Atkinson engine, and a new CVT tranny. I suspect Honda has done its engineering homework, but want to protect myself anyway.
The extended warranty (now totally 72 months) gives me 3 additional years, plus 100K mileage. Since I only drive about 8K miles per year, it was the TIME guarantee that was important to me, not the miles driven.
Gerald Frieberg, here in Appalachian Ohio
For me much of this is moot; I will be spending most of my time on the highway with this car anyway, where the vibes are no worse than my Ford Ranger or Nissan Murano. If you cannot tolerate some vibration, I'd advise going with a smoother engine (of the Toyota, Honda, Subaru and Ford SUV's in this size range, the Subaru flat six is the smoothest I have driven, while the Ford was probably a close 2nd place).
-Frieberg
I ended up leasing one. This will give me time to either love or hate it. The vibration is at minimum, as compared to some of the others that I drove, so there is a difference how badly they vibrate.
Then again, I felt some vibration driving a Rogue, as well.
