Transmission issue on 2011 Legacy GT (manual).
Sorry if this is the wrong place for this question but here goes.
Should I expect a diagnosis or educated guess from a Subaru dealer for transmission issues before i have to pay $1,400 for them to crack open my transmission?
I brought it to one dealer already and for the $120 fee my professional diagnosis was "something is wrong with my transmission" (which is why I brought it in). I'm hesitant to bring it to another without some idea they know what may be happening and what to look for. From the symptoms it seems they should at least have an idea what to look for:
The symptoms are it makes a clunking noise (like driving over small ruts in the pavement) only when warm and only when driving slow with the wheel turned sharply left or right. It does this in 1st, neutral, or reverse when warm. When cold it does not do this at all. It shifts smooth and the transmission seems fine all other times.
Best Answer
thecardoc3
Member Posts: 5,863
The description is only enough information to set the stage for someone else to go out on a road test and attempt to reproduce it. From there you need someone with enough experience and have the right kind of intuition to visualize where the back-lash is likely to be occurring and from there how the sound and sensation are being transmitted back into the car.
TSB's could then be accessed to see if there have been reports for similar issues and the technician would then need to investigate if they are plausible to what ever issue is at hand this time. Ultimately it eventually comes down to someone just might have to take it apart and do some physical inspection of the components and make end play and back lash measurements. There is a lot to be said for how much better cars are today and how few failures they actually have. But with that comes the reality that techs face many more once in a career failures than they ever did in the past and its quite likely that no-one that you are going to speak to has seen this before.
From the description alone it cannot even be judged as something that has to be repaired.5
Answers
