Visitor Agreement.
Also, in the vans conference, several Windstar owners are complaining of rebuilding the tranny from 40-60k miles.
Dwkidd, if I recall, one of the Chrysler van owners said he was told to change the tranny fluid at 15k or so, because the 25k interval Chrysler recommends is not good enough. The oil turns acidic apparently.
guitarzan
Community Leader/Vans Conference
I have put on 1200 miles in one month, yeah that sounds like a lot. I have notice that when starting from park and shifting into drive, there is a 2 or 3 sec pause then it kinda jerks into gear. It is getting a little smoother over time, but that seems abnormal to me for a new car.
Second, I notice that the rpm gauge is reading high for 65-70 miles per hour. It hoovers around 2800 to 3000. I am use to a four-banger. So when is the overdrive going to kick in or is that normal?
Lastly, At idle and slow speeds I am hearing this muffled tapping, like a da-t-da-t-da... sound, is this normal, I only noticed when I dropped my girlfriend off the other night, and heard the sound. Anyone with similar experiences or know what this is. Should I take the car in for service? Please Help.
Also last question, maybe a little off topic, does anyone change their engine oil at 1000 miles anymore, after the break-in period or should I go with the 5000 mile suggested by my manual where I used to do it at 3000 miles. Kinda of confusing in the beginning.
Thanks for all of your help in advance.
Alex
Every engine has a different rpm range. Do a search for "Jetta" in the search box, find a busy topic, and ask the owners in that topic about this.
Tapping could be anything, normal or abnormal. Mention it to the dealer and see what they say.
I recommend leaving your oil in. Some German cars have very hard rings and cylinders, and the original oil may break the engine in quicker. Do what the manual says.
Brodix, all a dealer will do is charge you more for the repair. Go to someone with a good reputation, who you can trust, dealer or not.
guitarzan
However, four quarts of ATF from the Honda dealer will cost about $7 more than a good Dexron III at the discount store. This cost difference is small with consideration for change intervals of 15,000 miles or more. For peace of mind, I would use the Honda brand. But, like you, I would still like to have the "inside story."
town and country mini-van. It's transmission failed. The van only had 65,000 miles on it and cost me $28,000 in 1996. What a joke of a product! Is there anybody going after Chrysler to sue them for the junk they sell? I want in!!!
guitarzan
Expect to spend about $1500 on a new compressor and dryer. Note that this is about the same cost as another transmission. If you buy a 97 or newer Windstar , expect the transmission to last at least 150,000 miles (given proper servicing at 25-30k intervals).
The Windstar is also twice as safe when hit from ANY direction - INCLUDING OVERHEAD !!
Dave
Well...some shavings are the result of normal wear and nothing more.
I wouldn't worry unless it starts acting up!
carlady/roving host
I coul not figure it out that why it was different before and why they are rolling back now.
Thanks, Mike
Just normal operation!
HELP!!
If I wait 15 minutes, and drive in 4th for a while, then stomp on the accelerator the same thing happens again. Is this due to the adaptive feature, is this normal?
I have a 1994 Suzuki Sidekick JS (4spd man. trans/2WD). I changed the differential and manual trans gear oil at 15K and found the same "Stick in a Bucket O' Rocks" shifting, especially in cold weather. Had not noticed difficult shifting before the change. At the time, my dealer was both a Suzuki and a GM dealer. Service writer said that the Sidekick Trans was very sensitive about the gear oil used and that they used an oil additive that GM marketed for the limited slip rear end of the Vette and equivalents. Not cheap stuff at over $12/pint, but VERY effective. That was 40K miles ago, just changed again, had dealer put in a pint of same stuff, and it is as slick as the day I bought her. (Rear end can use just plain GL5 hypoid gear oil in the correct wt noted in manual)
So, if you noticed this difficult shifting following a trans oil change, I'd give this a try.
I really love my Sidekick and hope to run it for a long time. (BTW, it tows my 2000# 17' Venture sailboat like a kid's Radio Flyer wagon.)
THANKS, Mike
Vehicle shifted well when new in all weather, (though I live in Louisiana, so cold is 33 degF).
In any event, I had the hard shift problem (especially in colder temps) occur AFTER I changed my trans gear oil w/ a std GL3 as recommended in the manual. I then spoke to dealer's svc writer, who recommended the addition of this gear oil (it is either a pint or 20 oz, I can't recall). So they drained out about a pint or so and added the gear oil. That solved the problem (this was in winter 1995). So, this year, when changing again, I just had them do it from the start.
I don't know the GM part number, but it is under a GM label, marketed specifically for the hi perf sports cars w/ limited slip rear end, and is intended for the rear end. The Chevy or Pontiac dealer's parts people should be able to identify from this.
If that is not possible, e-mail me at msibille@yahoo.com and I'll contact my dealer to get the GM part number, then e-mail same back to you.
Happy trails
I had it checked at the dealer and they said that it's in the transmission. The sound is excessive than normal. They will try to remedy the problem the next time I bring in the car, otherwise they would be replacing the transmission.
Please, I need feedback on this...
I noticed a whistling sound at 65 mph, and I would like to know if it's recommended to have the original replaced.
Feedbacks Please!
I am just worried that the noise might be a symptom to a bigger problem in the future.
warranty and now we just put out $1500.00 in transmission work. I am looking for anyone who might know of a problem with Blazer transmission or if there was ever a recall done or questioned.
http://www.nhtsa.dot.gov/cars/problems/
Please help!
Thanks- -
