Starter wire help
Hi guys can someone shed some light on how many wires bolt to the stud with 1/2 " nut on the back of the starter....I have the main positive off the battery cable ...there is 4 more junctions...not sure if 1 of them (or more) may be a ground connection because i didn't take them off. Is there anyway of checking the them with a multimeter to see what are the positive ones? besides the main positive from the battery i have a single thin wire ...one with four wires and two with 2 wires...any help would be greatly appreciated .
BTW. Make/model/year/engine/transmission would help. With that could pull a schematic and tell you exactly what you would find connected there depending on the vehicle options.
