Transmission stalls in reverse under slight gas, also in drive.
tslicetslice Member Posts: 3
edited March 2015 in Dodge
2002 ram 2500 extended cab 25.9 l gas auto 4x4 had problem cold would stall could drive with 2 feet keep it from stalling pulled trans went thru it found nothing but a 2/3 accumulator spring broken . replaced all selonoids
same condition and it now will not stall in reverse till slight gas put in to it as throttle pressure builds
going forward with slight throttle pressure shifts fine if i increase throttle pressure shifts 1-2 then locks up convertor with no signal from ecm when i come to stop will stall i dropped valve body i air checked trans all seems good replaced valve body same condition
  • thecardoc3thecardoc3 Member Posts: 5,858
    edited March 2015
    Check your transmission cooler for a restriction. We usually end up eliminating the factory cooler and installing an external unit.
  • tslicetslice Member Posts: 3
    i have 2 coolers radiator and a external do you think the restrictor could be clogged causing this ?
    It's been known to happen.
    if thats not the case any suggestions?
    edited March 2015
    http://www.atra.com/ If its not being commanded on, then it is falsely hydraulically applying. You might have a bad valve body and need it repaired/rebuilt.
