Visitor Agreement.
My new 2000 Honda Accord LX is hit by the tranmission problem. The last I heard from my dealer is Honda mechanics are changing the transmissions.
I wanted to ask you people how serious is it ? Should I press for a new car ? Please let me know. Thanks for your time.
Anand.
A link to NHTSA has recently been posted in some of our topics as a place to research and file complaints. You might like to check this out as well: http://www.nhtsa.dot.gov/cars/problems/
Good luck!
Pat
The transmission guy of course said it needs a rebuild (which at 163,300 miles on the original tranny was reasonably possible), so I had him do it. Now I will be taking it back to him, because the rebuild had affect on the problem.
My intuition is that this is caused by a $10 vacuum diaphragm or something. Anyone have any ideas?
Thanks, Mike
The dealer has been no help at all. Marysville is a small town so I guess I could expect this kind of treatment. ( See previous post )
Leroy Cook
It's working like new again...
dave
I don't like the major transmission chains. Many of them are thieves. A small, local guy I trust is always best for me.
The problem could simply be the oil pan gasket. Hopefully it is as simple as that.
Guitarzan
Community Leader/Vans Conference
My 97 escort (automatic) transmission has always been a little rough. When speeding up quickly (say, 0-30 from a stop sign in less than 20 seconds) it frequently, but not always, lurches a bit. I've had it looked at and they say nothing's wrong. Is a rough transmission likely to fail sooner? I know that some critics, including Consumers Reports, cited the new Escorts as being a bit lurchy in this category. I really don't care, I just want to make sure I care for it properly. It's done this from day one and the current mileage is 47,000.
In addition, the wheels lock up very easily and the tires squeal when turning at very low speeds, despite having new brakes and tires. This probably isn't related, but who knows.
--1997 Ford Escort LX 2.0 Liter engine Automatic transmission, 47,000 miles trans fluid last changed at 35,000, bought new--
My car has the Hold Light blinking and it does not shift to overdrive mode. Could anyone tell me that it has the transmission problem or not? Thanks in advance.
To BLURHENS you neeed to have every document the Dealer has generated. Also record every trip to get Service. Please include your E mail address when you post so you can get feedback quickly.
I am wondering if the front end needs an alignment to fix the tire squealing problem...?
Dmasters, that Ranger is 7 years old, with low miles. Would it be accurate to say it has been driven mostly city miles? If so, those are particularly hard on a tranny. HOWEVER, I think for your own sake you should try to track down exactly what was done to your transmission previously. Have a receipt? Then you need to find out, perhaps from an independent mechanic, if the previous problem has anything to do with the current problem. If so, you should then check out your other options. I don't know if Ford has an arbitration court, or if you need to sue to get results, or what. But others in the Town Hall may have such advice. Check out any Ford "problem" topics.
Guitarzan
If you haven't already, why don't you head over to our Finance, Warranty and Insurance conference? There are many discussions over there on extended warranties, including two topics on Warranty Gold.
Pat
I believe most newer a/t hold the gears longer when cold to warm the car up faster and reduce emissions. All my cars over the last 10 years have done that--some are more noticeable than others. I think the Japanese cars are most noticeable.
has a whine that comes from the manual
transmission. The noise occurs when you put
your foot on the gas pedal, not when the car
coasts or is in neutral. The noise reminds me
of some old trucks I have ridden in. Is this
the result of normal wear and tear or symptom
that a part is likely to fail soon?
in Torrance CA and they acknowledged the problem
immediately (they knew all about it), and they are
in the process of issuing a service bulletin now to
the dealers. Honda will install a new transmission
labelled as a "rebuilt" but don't be alarmed, they
get tagged as rebuilt because they are inventoried
seperately from the new stock. These ARE new
transmissions (after all there are no model year
2000 transmissions from old existing vehicles
available), they use existing "cores" (the outer
trany housing) and install all new guts. Everything
is checked for tolerances. Again, the cores are
really new as there is no inventory of used year
2,000 tranys. If this problem effects you - insist
on a 5 year, 60K mile warranty in writing from
Honda USA, they gave me one.
I have always had a stick before so am not familiar with automatic transmissions and their failure rate, but this seems a very short period within which to fail.
Anyone aware if this is typical or specific to GMC/Chev, or where I might go to find such info.
I am currently pulling a heavy RV w/my 89 Van that has 106K miles on it and no problems, but I also have coolers on it. If your Suburban has a towing package, it should also have a cooler...did it run low on fluid...? Has the fluid been changed..?
I had not been to that shop before and it is where I am having it fixed. My paranoia is that he sabotaged it while there for fluid change.
Can it be adjusted to have less accelerator pedal and shift only down to 4th?
If I step on it lightly like you discribed, it sounds like it is growling (loading down). If I tap the brake at the same time I lighty step on it, it will go down to 4th from the TCC and stay there until it gets up to the speed I need, but it won't do it with just the accelerator. My 98 GMC would instantly shift down with a tap on the accelerator. I'm wondering if this just the design of the 2000 GMC's. Can you shed a little more light on this. The dealer says this is normal. I can't agree.
Guitarzan
The problem I'm having deals with changing the tranny fluid in my '98 Dodge Intrepid. I know if I pull the tranny pan off, this isn't going to allow all of the tranny fluid to drain, some of the fluid still remains in the torque converter. Is it possible to drain ALL of the fluid from the tranny?
This leads to my next question. Since most of my driving is in town, I follow the most stringent maintenance schedule in my owners manual, which recommends changing my tranny fluid and filter every 15,000 miles. Now, since I'm not able to completely drain all of the fluid from my tranny, does this mean that I should pull the pan and drain out what fluid I can and replace the filter, or does this mean that I'm supposed to take my car to a tranny place and have them do a tranny flush? This is the only way that I know of to completely change out ALL of the fluid. I hope it doesn't mean to have my tranny flushed every 15K, 'cause at $140.00 a crack, this can get very expensive. If anyone knows of a way to completely drain this tranny, please let me know. Thanks.
Shop manuals almost always specify two fluid capacities; an amount "at change" and another (larger)amount "at overhaul". This implies that "change" means drain and refill (and a new filter) rather than a system flush. I agree with you that leaving approximately half the old fluid in the system does not seem like a good idea ...but the above shop manual wording effectively specifies exactly that. I concur that your frequent (15,000 Mi) change intervals should provide the best protection and longevity for the cost involved.
I would welcome comments from others as to why torque converters lack drain plugs.
Always follow manufacturers recommended service periods.
BTW, this is my first auto tranny car. Drove Manual 4 speed for last 12 years. So can someone be kind enough to explain how does the auto tranny works?
Thanks in Advance
Thanks for providing us a practical solution to the problem of no drain plugs on the torque converter.
This actually first came out in 1992 but it was re-issued in 95. My Q45 has 120,000 miles and the transmission has just went. I took it to a dealer and they never mentioned the existence of this bulletin. This bulletin extended the warranty of the transmission assembly to 7 years/ 100,000 miles. It no longer applies to my car, missed it for 20,000 miles. I am going to try to get some satisfaction from Nissan on this one. I just think they should have told me that this was a Nissan problem and offer some sort of assistance rather then just tell me it will take over $4,000 to fix it, take ti or leave it.
Does anyone have any experience with Infinity problems? Did you get your problems solved? I like the car very much but I have had to replace too many things lately. I certainly was not expecting one of the most expensive Japanese cars you can buy to start turning to scrap at 120 k. It certainly does not compare with my MB 300 CD, which I also bought used and has 160,000 miles on it. I will probably repair the Infinity at a garage in Michigan - Mitch's - they are on the net too. I hope they do a decent job, but since they are going to put in a used transmission I don't know. Any advice?
If you'll check www.Deja.com... autos.infiniti.Q45 ; we have some posts and recommendations about transmission problems.
A rebuilt with updates Q45 transmission (by Nissan sub in Tennessee)is available From Scottsdale Infiniti for about $1700 + freight.
Regardless of used or rebuilt, it is important to install an aftermarket cooler ($100) external and in parallel to the one in radiator in the event the stock unit plugs with debris causing overheat and failure.
Many of these units failed between 60-80K due to poor maintenance by owners (no 30,60,90K fluild changes). The dealer did not recommend flushes because the problem was unknown then, however most people understand the importance of flushing trans from previously owned makes and failed units.
If your trans was replaced and you have not installed extra cooler or are not flushing fluid regularly expect and budget another failure in the above time frame. With the above precautions 130-150k life is the norm,which is double most makes. A $120 flush every 30k is sure less expensive than a $3k transmission.
Warning: Diff will fail if you don't change fluid.
Q45man
thanks for your response q45man.
the owners's manual for '99 protege es does not specify any.
have not heard the following. My 1995 with 70k
has a vibration at times. The dealer said it is
the "clutch" in the transmission wearing out; $2400 repair or $4200 new. Anyone else had this
problem? Resolutions??? Thanks
on the steering wheel or in the engine.
when do you feel the vibration?
when shifting or idle or ...
Any advice is welcome.
There has been a lot of discussion in Town Hall about problems with the Windstar. I would recommend that you research these topics before making up your mind.
Good luck!
Pat
