A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
My problem is, well, a long story. Cruising in drive (overdrive is on automatically unless you remember to turn it off) you can let the car run on its own momentum, then give it gas, and the transmission makes a noticible bump. I was told it was normal. Whirring sound coming from transmission in first. Told it was normal on an FMX in another car, haven't had it looked at on the T-Bird. In shifting from OD to 3, shift happens at about 30 mph while slowing down, bad engine braking on this downshift. And the kicker-the car seems to hunt for gears, shifting rapidly back & forth between gears, usually when going uphill, but also when you are giving it just enough gas to maintian speed or slightly accelerate. I don't hod rod, (in fact, I drive rather conservatively), but the car had 139,000 miles on it when I got it, so I have no idea how the PO drove. Now has nearly 149,000 miles (I've had it since July). Something tells me this car has seen a lt more highway driving than in town. Anybody know if there is something specific wrong with this car, or is it just that 150,000 miles was more than the transmission could take? Thanks for your help.
Why, in a heavy powerful car do they last so long, the design is good but not extraordinary.
They use syn fluid and require that it be changed often along with filter (at owners expense). After the 60k warranty these 30k changes are continued because they are included in the price of standard service.
Why would any consumer expect a product life more than double the warranty without some consideration on their part. Like preventative maintenance.
Any transmission will last longer with regular fluid flushes sometimes doubling or tripling its un maintained life. How can you not spend $120 every 30kmiles to delay a $2,000-$3,000 replacement.
I was speaking of current designs as I was trying to warn people before the damage is done. I assume your 400k vehicles are +10 years old. Check out current 4 speed AT like Caddy,Gm trucks and RV, F vans, chry mini. RV, SUV.
Anytime you put decent torque and high weight together on an AT designed for neither you get problems.
According to AT Rebuilders Association 9 million AT are replaced/rebuilt each year due to heat related failure (90%). I expect a few are GM but the current winner is MB's new step child.
If this doesn't scare MB.
Pat
Another area of concern is that when the car is cold and I shift into Drive, the transmission doesn't engage from about a second, and when it does, a loud thump is heard and felt, and the car acts like it wants to jerk forward, stopped only by the presence of my foot on the brake pedal.
I reported these problems to the dealership, but
they said that it was normal for the car, saying that the Sunfire is a cheap car. I know that the Sunfire isn't a Lexus, but I thought that GM's autos had very good shifting quality. I've been in Neon's with antiquated 3-speed autos and they've never felt anything like mine. Can anyone out there tell me whether my transmission is supposed to behave like this?
post it again here. I want some more inputs.
I have Accord EX-V6 2000 (manufactured on Dec. 1999). From day 1, my Accord showed transmission shudder at low RPMs (below ~2500). It was most noticeable at around 50 and 20 mph when cruising. I took the car to the dealer, and after a couple of run arounds and a few phone calls to Honda, they decided to replace the torque converter in my car. Now I have a new torque converter, but the car still shudders at low RPM when cruising (although not as much as before, and the gear shift is pretty smooth now. no hard shifting from 1st to 2nd anymore.) Also, I feel little shudder right before the car comes to a stop when braking. Plus, recently (1500 miles) I hear a strange 'ta-ta' noise coming from the passenger side, mostly when climbing a hill at low RPM and constant speed.
I'm wondering if it's normal to have a shudder like this, even after it's been replaced with the 'good' torque converter. Is a small amount of shudder OK for a car with automatic lock-up torque converter? My Buick Century automatic never did this. I'm pretty happy with my Accord overall. It's just that mild shudder and strange noise that's been bothering me a little. Any inputs will be appreciated. Thanks.
--terminalis
I'm interested because my '92 Bonneville SSEi (96000 mi) is shifting harder and exhibiting an occasional jerk when going from stops. (No noticeable mechanical noises.) It has been flushed within the last year.
1.)Are there any adjustments to be made to it?
2.)Where can I find a schematic and parts/repair info online?
3.) Should I trade now or can I get another year or two out of it?
Any help much appreciated.
My '94 cutlass supreme has the early version of GM's electronic automatic. It was the first year they offered it in the Cutlass. They offered it earlier in other cars. My understanding is the reliability was not so great during the first couple of years, but has gotten much better since.
My car started doing what yours is doing at about 45k. Luckily I purchased the extended warranty. At 53k they rebuilt the tranny. Replaced some "rotoshaft" or some other thing I'd never heard of. It ran great for about 30K more then started the same thing again. I had the tranny serviced and it hasn't gotten much worse for several thousand miles.
Now at 94K and expect to replace the tranny somewhere around 110k. I hate to get rid of the car. It's been pretty good. Most of my problems have been related to dealer incompetence. No mechanical troubles at all except for the tranny.
I'd say keep track of the problem and see how fast it gets worse. You may very well be able to get another year out of it.
Honda Accord Problems here in Maintenance and Repair and
2000 Honda Accord Issues over in our Smart Shopper conference.
I know you've already posted in Honda Accord Problems topic, but I wonder if you read the whole topic? Your problem does sound similar to what was discussed earlier there.
I hope this of some help.
Pat
Did your tranny progress to complete failure when you had it rebuilt or just get more noticeable?
What's the usual (if there is any such thing) warranty period for a new differential?
Thanks!!
I got a question about Dodge Neon 1998 (or,
maybe, this is common for all Neons with auto
transmission?...).
I am going to buy this car in a few days and
tested it yesterday. Before I was driving only
japanize cars and and driving Neon was my first
experience with small american cars.
Is it common that you feel when you change gears?
From R to D , lets say.. The car is jumping up a bit every time you change from P to R or R to D ?
I don't feel anything when I do that in Civic...
I would appreciate any answer here, or you can
send it to igna@iname.com
But seriously, you might want to go to a dealer who has used Neons on the lot, and check the transmission in a car similar to the one you're buying. See if it feels the same.
If there is a problem with the car you're looking at, it could cost a lot to fix.
Another thing you could do is call AAA and have them send a mechanic to check the car out. I did that once, cost me $45. Not sure how much it is these days, but it would help you decide.
Dave
I brought the truck in Thursday morning to the dealer, and they handed off a Sentra to use as a loaner (after driving a "truck" I felt like an ant among giants on the highway)!
They did the work, and so far everything sounds fine. I've got great ears and will keep an "eye out" for any noises that crop up. This particular noise began fairly subtly, then became a roar by the time the parts came in (about 2 weeks).
Not fun at all on a new car with 2000 miles, I'll tell you, but what can you do. . . getting pissed off at the dealer wouldn't make it get fixed any faster or any more "free."
Thanks again for your help!
Kathy v
I love the Intrepids and am considering buying a 2000 Intrepid. However, Chrysler will only warranty the transmission (and all else) for 3 months/ 36 miles, unless, of course, you purchase extended warranties. I am very leery. Many, if not most, foreign cars, e.g., Toyota, give a 70-100,000 warranty on their transmissions. If Chrysler has any confidence at all in their transmission, why won't they warranty it until at least 70,000 miles? I love the styling, etc. of the Intrepid, but am really leary of buying another one, given the history of these transmissions...Any experiences, comments?
Bob c.
royals@erols.com
Made sure lines were cleaned,and installed new filter on replacement unit.
This first day I used it a peculiar thing happened.After stopping for gas,the car was restarted and no gears worked.I kept moving the selector and finally took off.No problems since??
What caused it? The transmission shifts and works great!
Pat
This is a well publicized problem on NEW Accords. Pat's right, what year is your car??
Your host, Bruce
I would like EVERYONE who's been reading these
posts concerning the v6 tranny problems to know
that I AM STILL FIGHTING MY DEALERSHIP (Orem,
Utah)to fix my transmission problems! I now have
34K miles on my coupe and am starting to sweat. My
car shifts VERY, VERY abruptly with a clanking
between 1st and 2nd gears. My dealership still
claims to know of NO PROBLEMS. I have not called
Honda corporate yet b/c I just started reading
these newsgroups.
For those of you who gripe about us complaining
about our tranny problems...PLEASE, PLEASE know
that this gets very frustrating (especially as a
3rd time in-a-row Honda owner) for my dealership to
be treating me like dirt and actually giving me
dirty looks and *gasping* rudely when I walk-in
because I complain about this. I HATE DRIVING MY
'98 ACCORD COUPE because of this 1st-to-2nd
shifting problem!
For Mr. "ISellHondas", buddy, listen...when you
spend $25,000 on your next car and it has a problem
as serious as this, I'll fly you over to my place
and personally buy you a gold-plated box of
kleenex's because I know how horrifying this has
been.
Honda is a great company and this Accord coupe
is (theoretically) a great car...I just want Honda
to know that I am NOT pleased at the disappointing
experiences I have had at the Orem, Utah dealership
trying to get them to be AT ALL helpful or
honestly wanting to help me.
Sincerely,
Jason Day
TheSasquatch@hotmail.com
I would like to hear from anyone who has had problems with the CVT.
Driving home my 94 Nissan Maxima w/auto and it slipped out of gear going up a small hill, engine would just rev but no go. I took it out of overdrive and was able to drive the few miles home. Once home I could not get reverse, but low gears work w or w/o overdirve on. I checked the fluid and it is nice red, no metal, full. Had both the 30 and 60 K service overhauls at the dealer, car now has 75 K miles on it. Am I looking at a complete failure here or could it be something simple (and less costly)?
HELP!!
HELP!!
My question is , can I replace my 1984 honda accord manual transmission into a 1986 honda accord with automatic transmission(don't like autos to much). Thanks
When you check check the tranx fluid in your car and the fluid stick says full, JUST ADD some more fluid because when its full in a cold car it means low when you drive it. This is usually the cause of trans failure and miss shifts. It will not hurt the tranx if you overfill the MARK on the stick not the refillpipe.
PS if it works, send me a check....just kidding.
Please post if you have this problem.
Symptoms if you hold the clutch in for 30 seconds or so the clutch will not disengage and the gears may lock out.
I have taken in my twilight blue ZX3 about 10 days ago. The dealer is replacing the master and slave cylinders, but parts aren’t available. I have just over 5000 miles on this car.
Also got recall notice for Injector Pressure Sensor.
Although the dealer gave me a loaner (Dodge Neon, best sales tool for a focus if there ever was a need to) I miss my ZX3!!!
$ for a rebuild ?. Thanks
