Misfire on a Pull
patmcclelland
Member Posts: 5
Our Town Car has been great for 260,000 miles with upkeep along the way. It has now developed a slight but irritating missfire between 40 and 60 mph on a pull at light throttle. It shows no codes. I had a real mechanic test for codes with his Snap-On reader; no codes. I had a good transmission man convinced that the original trans finally needed a rebuild but when he drove it he said the trans was good; it is a missfire. I replaced the fuel filter and 2 coils with questionable boots. 5 coils have been replaced. What do I try next?
Pat
Pat
If you had a misfire, then the more load the more severe the misfire. So if you can go up a long hill in top gear and not have noticeable misfires, I'd suspect the torque converter is locking and unlocking in and out of overdrive. Is there any "shudder" or is it a really "snap" type of hesitation?
Pat
