How to Change Your Oil Video | Edmunds.com
Edmunds.com
One of the cornerstones of DIY car maintenance jobs is the how to change your oil and oil filter.
Good video in general, but not a video I'd use as reference to teach a broad audience how to change oil.
I don't trust Chinese Harbor Freight jack stands either!
Twitter: @Edmunds_Test
There is another aspect of the video that should be addressed. The torque of the cap. Being these are phenolic (plastic) the torque is very critical and should not be guessed at. The cap really should be tightened with a torque wrench to ensure that it hasn't been over-tightened which leads to difficulty in removing it in the future and ultimately a failure of the assembly.
A real oil change at the local Sullivan Tire = 27 bucks with the usual 7 dollar coupon online
Not worth 7 bucks to jack up my car or put it up on ramps, change the oil and then dispose of it.
It would barely be worth it if I still had the Cutlass 442 I could slide under....
Just never go to a Jiffy lube type place, they just vacuum out the oil and never get it all. I went once in a pinch and my oil was still dirty after...
http://www.edmunds.com/how-to/the-top-down-oil-change.html
