No spark
the enging does not have any spark the people we bought it from installed a different PCM no change , new egr, plugs look fairly new and are platinum, battery was bad replaced it, engine cranks over but will not start, the box on top of the plenum is also new, cam sensor is new. any thoughts?
DESCRIPTION AND OPERATION
The powertrain control module (PCM) controls engine ignition through a solid-state switching unit called the ignition control module (ICM). The software in the PCM uses input from several sensors to determine the timing, duration, and strength of the spark.
The crankshaft position (CKP) sensor sends the PCM a 58X signal related to the exact position of the crankshaft.
The camshaft position (CMP) sensor sends a signal related to the position of the camshaft.
The knock sensor tells the PCM if there is any problem with pre-ignition or detonation. This information allows the PCM to retard timing, if necessary.
Based on these sensor signals, as well as engine load and engine coolant temperature information, the PCM controls the switching function of the ICM by sending it a six 5V signals. As long as the ICM receives the signal, it allows battery voltage to the ignition coil. That voltage allows a magnetic field to build in the coils.
When the PCM requires each spark plug to fire, it shuts off the 5V signal to the ICM for that plug by grounding it internally. This triggers the transistors in the ICM to switch off the battery voltage to the ignition coil, which causes the field to collapse.
The lines of magnetic force pass through the secondary portion of the coil as they collapse. As they intersect the coil, they induce high voltage in the secondary ignition circuit which travels toward ground through the spark plug.
the icm had been replaced with a new one but it was bad the parts store said they do not guarantee electrical parts so we picked one up at a salvage yard started right up ran fine!!!
