HHR Control Bushing
murcogmurcog Member Posts: 8
edited May 2015 in Chevrolet
Can i just unbolt the two inner bushing locations and "swing" the arm enough to change the inner bushing?
  • thecardoc3thecardoc3 Member Posts: 5,876
    Almost. Is the sway bar link connected to the lower arm? If so then that needs to be removed, otherwise yes.
  • murcogmurcog Member Posts: 8
    sway not hooked, got control arm out, removed rubber bushing, but steel sleeve on new bushing is same size as hole? do I just push rubber from new bushing into old arm?
    thank you cardoc3
    new bushing has steel sleeve around bushing?
    edited May 2015
    Yes, the vertical one does. The horizontal bushing does not, but that one usually does not need to be replaced.
