sway not hooked, got control arm out, removed rubber bushing, but steel sleeve on new bushing is same size as hole? do I just push rubber from new bushing into old arm?
thank you, all done! was easier to replace entire arm after I found out I didn't have the right "core drill" sizes to press properly,,,,Thank you thecardoc3 for your time
