Transmission hesitates then jerks into 1st when starting. Need GM rep to help.
z9scottyz9scotty Member Posts: 3
edited June 2015 in Chevrolet
The warranty for the transmission expires in September. The previous owner took it into the Chevy dealership twice with the same problem two months ago.. However, there was no engine light and the dealer was unable to duplicate the problem. It has happened twice to me in the past month. Same problem, no engine light and I cannot duplicate it. From a stop, you press the gas and nothing happens and then after 2-3 seconds it pops into gear and lunges forward. Any suggestions on how to get the dealer to identify and fix this while under warranty? Could this be covered by the service bulletin TSB 4/18/2012, subject UNKNOWN or OTHER describing the need to replace the control solenoid - PCS? Thanks!
Answers
  • kyfdxkyfdx Moderator Posts: 269,655
    What model Chevy? What year? What engine?
  • z9scottyz9scotty Member Posts: 3
    2011 Impala 3.5L V6
  • larryb1963larryb1963 Member Posts: 26
    Take it to another dealer . they should find the problem . tell them you want it documented . if it goes bad you have proof it a on going issue call GM 800 # talk to them .
  • impalamikeimpalamike Member Posts: 4
    any luck with the issue you had?
    It turned out to be a problem with the fuel. The winter grade fuel in particular. I used a higher octane fuel and haven't had the problem since!
