Ac problem
HeLPPPPPPPPPPPPPPPPPPPPPP
I HAVE A PROBLEM WITH MY 06 IMPALA AC. SOMETIMES BUT OFTEN, WHEN I HAVE CAR TURNED ON BUT ON PARK OR AT A LIGHT, OR STOP SIGN MY AC STOPS BLOWING COLD AIR AND HOT AIR COMES OUT, AND THE LIGHT FOR AC TURNS OFF AND WHEN I PRESS BUTTON TO TURN ON AC ALL IT DOES IT BLINKS LIKE 2 OR 3 TIMES AND AC DON'T TURN ON, SOMETIMES IT DOES. BUT AC STAYS ON OR BLOWS COLD AIR ONLY WHEN I RUN THE CAR. WHAT COULD BE MY PROBLEM, PLS HELP. HAVE A 1 YR OLD DAUGHTER AND THIS AC PROBLEM IS WORRYING ME MOSTLY BECAUSE OF BABY, BECAUSE AC TURNS OFF RANDOMLY WHEN CAR IS AT PARK SHIFT OR WHEN I'M AT STOP SIGN OR LIGHT.
Answers
CHECK THAT NONE OF THEM HAVE COME LOOSE AT THE ENDS. THEY SHOULD ALL BE PLUGGED INTO A NIPPLE OF SOME SORT EITHER ON THE ENGINE OR ON THE FIREWALL ( engine compartment side of your DASHBOARD)
