Visitor Agreement.
As to your insurance premiums, what do you think? Insurance companies love taking your money, they hate giving any of it back. If they can legally do so, they will raise your rates. I don't think just the fact of a claim is enough, but it might be. Maybe they would claim you are a bad risk because you park under chemical trees. They could always just not renew you as a pain in the rear and then you would have to find a new company and the fact you were not renewed would count against you. I doubt that the increase in premium would even come close to equalling the $3000 they have paid you. I think you lost any way you look at it. Take the money, keep it, don't paint it, trade in the car (at night? ) and run.
The idea is to use car model builder's painting method to paint your chips and scratches. I used this method to repair some pretty bad paint damages on my car and the repairs are all but invisible.
1. Perfect window towels.
2. The best glass cleaner available.
It's taken me 20 years to find this stuff. I'll give you the inside scoop free.
Glass Cleaner - Eagle One 20/20. I've also used the glass cleaner from Henderson Glass (for those of you in Michigan) and it's excellent. I have not used Stoner but heard good things. Also the glass cleaner from Griot's Garage is terrific.
Window Towels - Griot's Garage blue polypropelene towels. By far the best item of its kind I've found. Expensive but worth every penny. Order from Griotsgarage.com. If you are a car lover ther Griot's catalog is a "must have".
If you want an easy One-Two punch, buy the Griot's glass cleaning kit and enjoy perfection.
My wife accidentally scraped the right rear fender of her 2000 Honda Accord SE against a concrete pillar. Luckily, she was going quite slow. Assuming the fender is about a 180 degree arc, the scratches start at about the top and run along the fender to near the bottom right. Also, just a small one on the door. There are places that are completely untouched, and others that are just to bare metal. There are no dents at all.
One body shop I took it to said that I would need all new sheet metal (well over $1,000), since "rust will always come back." A friend of mine who knows cars said that perhaps a detailer could take care of it.
I would like to just take the easy route, and try to do it myself, or maybe just stop the rust that is starting to form. Do I have to mention this when the lease is up (13 mos)? Is this something that someone fairly comfortable with cars can do themselves? Can I just take care of the rust with something and then carefully prime it and have a body shop do the rest?
Thanks for all your help, everyone. I look forward to hearing what you all have to say.
Sanding, maybe a touch of filler, priming, and repainting the panel is prolly a $300-500 job.
Do you have to mention it when the lease is up? No, because they'll notice it anyway. When you turn in a lease your car will be inspected prior to maturity date. Inspection will be done by a dealer or a third party. They'll find the scratches alright.
It's kind of a judgement call for you. I had two dents with serious scratches on the hood of a leased Infiniti. I decided to leave them. An inspector checked out my car before lease termination. I was charged only $160 for the damages, a lot cheaper than body shop prices. Of course, your mileage may vary. But you will pay for it one way or the other.
Hope this helps.
However I heard that waxing a new car is not a good idea as the wax is "too strong" for a new car's paint, and it is better to do so after 6 or 8 months. Is there truth to this???
Dealer body shop wants to redo the entire fender...
Anyone had experience with dent removal jobs in the past? I do not want to re-paint the panel if dent removal will do the trick.
I do shake it out very well each time before and after each use.
any suggestions?
Is there an easy and cost effective way to fix this? If I take it to the local dealer, I am sure they will propose a cost prohibitive solution.
When I got the car back the first time, the grey was a slightly lighter shade and the flecks, although the correct color, weren't bold enough (there wasn't enough fleck and the paint looked dull). I pointed this out and they agreed it didn't match and promised to fix it.
The shop explained that they matched the color from a book...by eye the first time, since no paint code from the manufacturer was available. They explained that for the second attempt, they would use a special camera to analyze the paint, which is a lot more accurate.
When I got the car back the second time, the bumper color matched perfectly, but the flecks are simply silver (no purple or green). I cannot tell exactly where the green and purple flecks stop and where the silver starts, but the shop obviously removed the cladding over the rear wheel well and did a "fade" somewhere.
It is only obvious during daylight, and only up close.
My question is this. Is it reasonable to expect that a body shop should be able to perfectly match the paint, flecks and all? What are the industry standards? Do I have a beef, or is this within normal tolerances?
Al
How much should I expect to pay for the paint job that equals or betters the factory paint job? And will the baking process of the paint prevent bubbles from appearing? Thanks in advance.
P.S. I was told that my burgundy red is more expensive than other colors. Is this true?
"Bondo" won't work since the bumper is flexible.
Questions to ask: Does the body-shop pull off all trim, decals, stripes, and anything else attatched to the body before the repaint and then re-attatch it all after, or do they just tape off everything. Removing it all decreases the likelihood of overspray, or getting paint on things like weatherstripping and body-cladding or other places where it's not supposed to be.
Stripping the body is more expensive but will pretty much eliminate over-spray.
Where do they dry the cars off? I've seen some places that just sit cars outside to dry after repaints. Totally unaceptable. To make sure nothing contaminates the paint before it hardens, make sure they dry it inside, ideally by baking it.
Bubbling paint: More than likely caused by poor surface prep, such as faulty primer(the stuff that goes on before the paint so that it sticks better) or insufficient cleaning of the surface and removing of wax residue prior to painting. How long ago did they paint it? IF the work is warrantied I'd either ask for a refund or have them redo it if they dont give refunds.
The steps to repainting a car(way oversimplified to keep this short but to give you a general idea)
1 Removal or masking of all trim, wheels, tires, windows, etc...
2) Removing old wax
3) Sanding down of the old paint or removal by some other means such as chemical paint-remover. Some body shops will go all the way to the sheet metal, some will try to leave sections of primer if they're still healthy.
4) Remove or repair all imperfections such as dents, dings, rust, etc...All those little things that can cause big imperfections in the new paint or problems after if you just paint over them.
5)Re-apply primer
6)Re-apply paint
7) Re-attatch or unmask trim after paint has dried.
You could pay 400 dollars for a mediocre paint job if you just want to cover up the sheet metal and keep the car from looking totally ugly, or you could pay upwards of 5 thousand dollars for something that looks better than factory and will shine and hold up to the elements for years to come. Some people pay upwards of 10 thousand dollars for a paint job. There is really no perfect price because people have different expectiations depending on how old the car is, how long they plan to keep it, how much they can afford to spend, etc... The problem is lots of times they think they can get a great million dollar paint job for 400 dollars and then when expectations are not met they get angry/disappointed. It all depends on how old the car is and what you want to sink into it, but you will get what you pay for.
You said, "2-3 thousand dollars for an entire repaint if done fairly well." Among that 2-3 thousand dollars, how much would you say is for the labor? With proper equipments (how much are they?), is this something you can do in your garage? Thanks again.
Have you ever done any painting at all? If not, I do NOT recommend you attempt a total repaint. Completely repainting the vehicle you drive everyday is not the place to learn for the first time. It is much harder than most people ever realize, and if you have no experience you'll probably find the job taking much longer than you expected because of all the areas you have to redo and all the mistakes you have to fix.
Little surface imperfections that you think are small enough to ignore will show up through the new paint three times as badly. Screw up on a panel and lay the paint on so thick that it runs and you've got to wait for it to dry, sand it again, and start over. And I guarentee that you will do this if you've never held a spray gun before.
Here is a partial list of necessary materials just to give you an idea.
Power sander, chemical paint remover, or both, along with lots of sandpaper.
Exhaust fans: These suck the air away from the car to decrease the likelihood that dust and lint will get trapped in the new paint and also help suck away those toxic paint fumes.
Masking tape: To cover up windows to prevent overspray.
An old raincoat and some plastic bags to go over your feet: Otherwise you might find when you're done that your shoes and clothes are now a new color.
Spray gun: 100 dollars minumum for a good one.
Paint
Primer
Clearcoat
An extra $3000 on top of what you spent on materials so you can go to a bodyshop and have them fix your paint job.
In case you don't get it, I strongly recommend against you painting your own car unless you have experience doing so, and the fact that you had to ask me about materials indicates you do not. If many bodyshop pros have been doing it for years and STILL produce shoddy work, what does that tell you?. If it's an old car and the paint work doesn't have to be top notch, consider just sanding the car down and then paying Maaco or Earl Scheib to run it through their paint booth, which will probably only cost a couple hundred dollars. Sanding down the old paint is what requires the most work, but it's not something that is as dependent on technique and experience.
http://www.autobodystore.com
The owner, Len, also has a bulletin board, and he (and other knowledgeable posters) answer a lot of questions there.
I'm not saying you should try painting your car yourself. eharri3 is right. But you might want to know more about it, and, who knows, try it yourself on a dent repair sometime.
Thanks in advance.
A good body man is hard to find, takes years to learn the nuances of doing it right.
-Larry
Just too much money.
dave
IMHO, save the money, pay to have it detailed twice a year, and they'll most likely use something better than the "miracle lifetime paint protectant" that is called "Turtle Wax" at your local Walmart.
QUESTIONS: So.... would you wax a brand new car? And would you put anything on the leather seats for protection?
