How long can one keep a 98 Avalon?
                    right now i am having problems with an oil leak. In the process of trying to fix it, they replaced the cam shaft, did sealings, replaced the water pump all all belts. it still leaks oil on the driveway. The car has 140,000 miles on it and is 16.8 years old. How long does a 98 Avalon last or should I listen to the mechanic and start lookng for a new car?
Sometimes the advice "buy a new car" is good advice, but sometimes it's a code word for "I give up. I can't fix this thing".
No reason why this car cannot run reliably up to 225,000 miles. You've got another 7-8 years here.
Oil leaks can be a matter of doggedly tracking down the leak, and replacing gaskets or correcting excessive crankcase pressure.
