Viper, No Viping - 2015 Dodge Viper GT Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Our 2015 Dodge Viper GT is brand new, which means we must follow a fairly specific break-in procedure before we unleash its true potential.
The bigger concern requiring a break-in process for most manufacturers is the driveline components such as transmission/transaxle, clutch, differential, axles and brake components. I want to say that the Viper is using a twin-disc clutch in its six-speed manual, which if I had to wager a guess probably requires the most consideration for break-in if they're using a partially organic-based friction material to give it reasonable streetability.
Combined with not trying to require an owner to properly bed-in brake pads, engine components that might benefit extended running that the factory can't perform (e.g. possibly the cam-in-cam phaser components in this engine, rings depending on tolerances, multiple-displacement lifters for cylinder deactivation, etc.) and it may be safer to give the car a little time.
Sure, it will probably still last and provide a longer service life if you jumped in and started hammering it but maybe some components would get a little longer life in the long run if care is taken when new.
Twitter: @Edmunds_Test
I've done the motoman break on my Kawasaki Versys and a friend of mine did it on his 06 corvette. I have gone up to 6000 miles between oil changes and it has never used a drop of oil. Have 50k miles on it now and runs great. My friends vette was the same way. He tracked it and it did dyno on the high side for LS2s. I think he got into the 12s with it at Rock Mountain Raceway that is at 4000ft elevation.
I think the key is to take it easy until the engine is warmed up then get on it. I could see how people would be leery to do this on a $100k+ car but given the amount of variables of how people are going to drive within the first 1500 miles I don't think it is that critical for a good running engine.
We've all seen videos of people who just took delivery of a Hellcat, Corvette Z06, Nissan GTR, Shelby GT500, et al and immediately wrapped it around a tree/pole/stationary object or just plain wrecked it. Happens all the time. One hopes these drivers would respect their new vehicle and not let the adrenaline of owning a brand-new example go to their heads.
