A/c and tire pressures
First would be the tires state max 51psi. is that what I want to put into these tires? I got the car used and they have 35 psi. or so in each, also I got an a/c recharge hose and can the hose end is too small for the inline valve i guess i am to use to fill? The only other valve I see is low and in the rear of the engine compartment, this recharge hose does not fit that one either , its too large?? thank you in advance for any help p.s. this is a 6 cylinder motor.
