Down a Quart After 2,000 Miles - 2015 Kia K900 Long-Term Road Test
Edmunds.com
I checked our 2015 Kia K900's oil level and found it was a quart low, which was a little surprising given that our last service with an oil change was just 2,000 miles ago.
http://www.cartalk.com/content/when-are-you-supposed-check-your-oil-when
RAY: But a few years ago, Ford Motor Company started recommending that people check their oil on Fords, Lincolns and Mercuries when the engine was warm.
TOM: "Warm!" we said. "How can this be?" So we called Ford and they told us that they determined that very few idiots like us were going out first thing in the morning in their bare tootsies and checking the oil. Most people, they said, tended to check their oil when they stopped for gas, when the engine was warm. So they simply recalibrated their dipsticks to read correctly in a warm engine, when the oil has heated up and expanded.
RAY: He said the amount of oil at the top of the engine wouldn't be enough to make any significant difference. "Unless the oil passages are all plugged up, you're probably talking about an eighth of a quart or less," he said. Not enough to induce you to add a quart when you don't really need one.
TOM: So there you have it, folks. The answer is; it hardly matters. So our advice is to follow the instructions in your owner's manual when you're in the mood for a really accurate reading. If it says to check the oil cold, the dipstick has been calibrated for cold, unexpanded oil. If it says to check it warm, we and Deep Dipstick hereby give you our heartfelt blessings.
