I'm working on a friend's 07 Toyota van and after replacing all pads and rotors there is a thumping.
fast69dfast69d Member Posts: 3
edited July 2015 in Toyota
Thumping noise in rear passenger side. I removed pads and rotors, inspected and found nothing wrong. I decieded to replace the new rotor with same and the thumping is still there, but only with the brakes being used. Nothing felt in the brake pedel and the the van stops fine. So why the thumping noise?
Answers
    Is this one "clunk" or a constant thumping that increases and decreases with wheel movement?
  • fast69dfast69d Member Posts: 3
    There is a constant thumbing that increases and decreases but only while applying the brakes.
    the thumping is only in the passenger's rear.
    Broken wheel stud or loose hub? Still scratching my head here.....
