Flat Tow a HR-V 6-Speed behind an RV?
I've been searching the interwebs and not seen any info about flat-towing a manual transmission HR-V behind a motorhome.
I have seen others ask this question, but the only answer is no, you can't tow the automatic transmission model with all four wheels on the ground.
I do see that the HR-V is based on the Honda Fit AND I see that the Honda Fit manual transmission model can be safely flat towed behind an RV.
And since A=B and B=C you'd think that A=C. I can't figure out why no one has any info on this. So, if you have some, info on this, please share it with us.
