Diconnected hose
invaderzim3288invaderzim3288 Member Posts: 2
edited July 2015 in GMC
i have found a hose diconnected laying close to my throttle and cruise control. I beleive it to be a 5/32. I have followed all the way behind my battery connected to a electrical plug with two hoses coming from it. I cannot find were the other end connects. Please help with this. I feel this is linked to my truck feeling bogged down for the first 30 to 45 seconds upon accelerating from a cold start. Thanx in advance.
    One trick I use is to stretch the hose out straight and then make an arc across the engine, looking for the place it might fit. You know GM makes the hose just the right length, so............
  • invaderzim3288invaderzim3288 Member Posts: 2
    Great advice. However i tried that. Pulled it every which way i could. Even looked up hose and electrical maps. Couldn find a thing that helped. I will make a second attempt first thing on morning thanks.
