Compressor turns on if I jump it, but the relays are good.
Just had a complete service done to my a/c system on my 2000 CRV because the compressor wasn't coming on. It's ready to go, but my compressor won't run. Service tech says that when they jump the compressor relays, the compressor runs and the a/c works the way it's supposed to. Says there's something wrong with the electrical system between dash and relays. Any ideas? The cabin fan only works in high as well, none of the mid-range settings. Related issues? Thanks!
Answers
What does the PCM data stream show, is the PCM receiving the request to turn the AC relay on? If so does the data show that the PCM has made that command?
