Plzzzzzzzzzzzzzzzzzzz Help
khillmankhillman Member Posts: 3
edited August 2015 in Toyota
Recently i changed my alternator, then all of sudden when i drive for about 15 mins it starts to overheat i pull over by a shop thankfully. And the guy let my car cool off, vaccumed pumped the air out and added water , befor i could get hm , in overheated again , i let the car cool off, tried to re burp my car to no avail a diy, turned the car, my druve way is slated so that was an advantage, turned the heater on full blast but a fuunel in and started to add coolent, fustrated for over 30,45 mins still nothing so i came in to toyota for them to find the problem first thing the next morning been here since 8.30 now its 12.45.. so tey burped the sytem ,clean my ac system
, oil change ect.... im happy..... so i leave excited, i get down the street and it overheats again !!!!!!! I turn around and bring it back with the needle past the hot red line. No smoke or leaking anywhere....Omg wht can be the problem.......? Plz any suggestions, i have a warrenty but no news yet......help,help help...thks in advance
    electric cooling fans not working?
  • joejoesonjoejoeson Member Posts: 44
    Are you sure your system has the 50/50 water/coolant mixture? Some guy adds water to your system, you add some coolant, are you sure you have the right ratios? And you didn't mention if Toyota checked this, you just said they burped the system, cleaned the AC, and changed the oil (motor oil?) None of that has to do with the engine coolant.
  • thecardoc3thecardoc3 Member Posts: 5,876
    Is it overheating while driving, or does it happen when you get stopped in traffic? (or both)
