-June 2024 Special Lease Deals-
Vehicle Break-In Period
RE: Car on Lot since Nov. 2000----what I want to know is WHY didn't this car sell? That is the REAL question here.
Agree on tires & oil fer sure...change oil, and pay close attention to the tires --- probably OK, but check carefully.
Actually, some manufacturers put stuff in the original gas to keep it from gumming up for just this sort of "shelf life" thing. We blend and sell such a product at the place I work...no way of know if your manufacturer does use similar additive, but you could ask the Dealer and call the customer service line for coroboration. FWIW, kida like stuff for lawnmower fuels...
I have never heard of a new car having problems with old gas, but yes, I have seen cars that are left to sit too long have injector problems and sometimes fuel pump problems from bad gas. I believe the gas "separates" and part of it turns into a varnish-like substance. Very common problem in lawnmowers also, which is why you're supposed to run them to empty at the end of the season.
I hope I didn't lower everyone's opinion of me with my confession!
In my case, I have never gotten over the "old" notion that metal particles, and other detritus MAY be circulating in the break-in oil, as the engine runs in, and smooths further the machined surfaces that require lube. The filter may therefore get "contaminated" early on, and who wants to fully trust that something won't pass the filter and potentially recirculate?
The oil change intervals for the new Acura RSX are amazing. 5000 miles for severe service and 10,000 miles for regular service. They have pretty much made that car less of a hassle to maintain compared to the Integra.
I went 1300 miles for the first change then again at 3000 then every 3 months regardless of mileage. My driving is mixed LA traffic. So I'm being silly, but "break-in" means wearing in really,parts burnishing themselves down under load and this DOES enter the oil I don't care how well made the engine is.
With the price of a new vehicle so high; why would anyone NOT make the first change an early one, say HALF the manufacturer's recommendation?
I also don't buy this "sealed for life, never needs changing automatic trans fluid". To me it's sort of like Ford's "Never needs waxing" paint in the early 60s
http://batauto.com/
Does an engine block heater help keep damage to a minimum during cold starts.
What should the typical odometer mileage be on a new car? What was yours?
Does anyone else have any comments on the max speed? I am not racing or speeding, but want to know if it is really worth going 55 in a 70MPH zone. People here in Kansas City are not the patient type being behind someone going 55. :-)
The manual states nothing about recommended speed.
Is there any other recommendations from anyone else out there on what to do during break in that is not in the manual? How about the first oil change?
My opinion on break-in oil and oil changes: follow the manufacturer's advice. I now have two new vehicles being broken in: a Ford pick-up truck calling for 5000 km oil changes and 1500 km first oil change, and a BMW330 with the next oil change projected to be at about 24,500 km. I had a 1987 BMW that predicted oil changes/service with a row of lights and the interval averaged about 16,000 km if I remember. Contrary to what I read in an earlier post, the long oil change interval for these cars is nothing new.
Break-in periods on todays modern cars are not nearly as restrictive as they were 30-40 years ago. My Audi salesman told me "don't be afraid to take it right up near the redline for short stints during the break-in period." I thought no way am I going to do that. He stated that it's recommended as that's the way modern racing engines are broken in. Well, I didn't dare take it up to the redline during the first 1K but I did rev it up to 5,000 RPM during acceleration serveral times for short bursts during that period. The Audi owner's manual has no RPM restriction during the break-in period. And as you've probably witnessed as I have, some dealers will let a salesperson take a brand new car with less than 10 miles on the odometer, out on a test drive and just beat it to death showing it to a prospective customer. Not the ideal thing to do in my opinion but I really wonder if that particular car will have any real issues later on down the line because of it ...my sense is that it probably won't. I've purchased more than a dozen new cars over the past years and never have I really worried or paid that close attention to the way I drove during the break-in --and I have to add that I've never had any major engine problems with any of those cars even after many 10s of thousands of miles.
So in summary, just drive "normally" during the break-in period. You shouldn't let it restrict you from taking a trip, going to the mountains (oops, probably not many mountains around Kansas City *lol*), hauling a moderate load of either cargo or passengers, etc. Just don't floor it or give it full throttle, do wheelies or jack rabbit starts or stops, or use the cruise control for sustained periods during the first 1,000 miles. So re-check your manual for either the MPH or RPM restrictions that most manufacturers will state in their break-in instructions. If Nissan doesn't state either of those restrictions under their break-in instructions, then IMO it's perfectly okay to just drive as you normally would ...assuming, as you said, that you don't drive like a racer or excessively speed on a continual basis.:-P The only other thing that you might normally do but shouldn't during break-in is tow a trailer.
One other opinion I might throw in: IMO, one of the most damaging things you can do to your engine is to rev it to high speeds when it is cold ...whether in neutral or in gear. This would apply at any time, even after your break-in period is over.
The first oil change and subsequent oil change intervals should also be stated either in the owner's manual or more likely in a separate maintenance manual that you were given during delivery.
Enjoy your Altima! ...it's a sharp looking car!
--'rocco
attempt to constantly vary engine and vehicle speed
avoid engine speed over 4500 RPM
avoid vehicle speed over 100 mph (160 km/h)
no full throttle acceleration (no kickdown for auto tranny)
after 2000 km, increase limits gradually.
This is probably overprotective. It is very hard to keep the RPM under 4500 in the first two gears unless you keep your eyes glued to the tach.
My last BM (87 325i) did not have such a protected youth. I bought it as a repo with under 11,000 km and worn out Z rated tires and clutch. In the first month, I missed shifts twice with it pushing it to 7500+ RPM for fractions of a second at a time. I hit the rev-limiter regularly with it. It is now with its third owner (a friend) and approaching 280,000 km with no engine trouble at all.
For the Ford truck, the 5000 km oil change is for heavy use. For normal duty, it is 8000 km.
I have tried to be very conscious of not letting the rpms go over 4500 and to vary engine and vehicle speed. This is must easier said then done with this car.
Even with the step trans in "regular" drive mode there have been a few occasions when I noticed the tack surpass the 4500 mark. With a car like this it is very easy to do without flooring it or driving like a maniac.
I have maybe gone over the 4500 mark 3 times just barely for a few seconds each time and once I went to 5800 once for like a second.
I was not happy about this but I feel that this will have very little effect on the engine in the long run since for the other 99.9% of the time I am following the breakin to the letter.
I avoid using the "sport mode" and the "manual shift mode" because it is even easier to go over on the revs very quickly without noticing.
I do constantly vary my speed and vary my acceleration from easy to moderate to keep the engine running in a larger rpm range. If you don't push the car a little it will never get much over 2500 rpms.
CNorthrup
