04 Grand Caravan complete shut down
                    I have an 04 grand caravan sxt 3.8 v6, and while driving, will intermittently shut down. engine shuts off, gauges will "max out", and all power is lost. no power window/lights/door locks, no electrical power to anything. I removed battery tray 2 days ago and cleaned the ground wire attached to inner fender, and replaced the battery temperature sensor in the bottom of battery tray. Problem fixed for two days. today, shut down and won't restart. ant ideas are appreciated
You might scan for stored codes to see if the car's computer can give you any hints as well. Such a condition as you describe can be caused by many many things, so throwing parts at it can get very expensive.
