Show Me the Tire Pressures, Please - 2015 Volkswagen Golf GTI Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Not all tire pressure monitoring systems are created equal. Our 2015 Volkswagen GTI has the dumb one, apparently.
Ironically, it is the newer system that do not tell the specific pressure. Some Acura's like the ILX have gone to the no-sensor in the tire method like above and some like the TLX still give individual pressures.
"should not change the fact that drivers and owners need to take responsibility"
It can be more frustrating than not having a warning since it doesn't tell you if the tire has just gone slightly below the correct level or if it is rapidly deflating with a chunk of metal in it and you have to stop before you get to that stretch of road with the construction barriers on each side and nowhere to pull off.
I personally like the sensor-based systems. If a tire is going to go low, especially on a car that only comes with an inflator kit, I want to know the severity of the leak. And for track cars it's nice to see an estimate of how temps are altering pressure. The sensors can be expensive but have come down quite a bit and there are decent aftermarket units as well. My GM sensors for example can be had from $25-40 each. Considering I got about seven years out of the stock ones on one of my cars that's a price I'm willing to pay for the added info they provide.
If VW will only display a warning, the ABS sensors are fine -- I check my tires regularly anyway. But for all the expense of the RF TPMS sensors in each wheel, it's plain cheap to not display the actual readings somewhere on the dash displays when requested. Frustrating.
While I can also work a tire pressure gauge, it is nice if you're driving a lot of miles to be able to track the pressure at each wheel from inside the car, especially so for slow leaks. And when the warning light goes off I'd want to know if I need to stop immediately and hope to save the tire or if it's just low. With how often tire pressures fluctuate and with the trigger point on some systems being so low the check tire pressure warning can come on occasionally. And I personally hate potentially bad/erroneous/missing data as much as not having it in the first place.
There is more to know when it comes to TPMS systems then most want to know. Things like which cars require retraining for even a simple tire rotation and which ones don't. Which ones require a TPMS tool, and maybe even a scan tool as compared to which ones don't. Which cars used banded sensors, hard stems, soft stems, sensors mounted in the tire itself (like a tire patch). If that's not enough techs have to contend with some systems that self identify using the ABS and motion sensors inside the TPMS sensor to determine wheel speeds, and other systems that use initiators that command the sensors to report and the controlling module learns the location of each sensor that way. That BTW brings up another whole level of sophistication. Which module on the car receives the wireless data from the sensors, and then how is that data transmitted to the instrument cluster or driver information center?
The best part of all of this is how few people really understand exactly how to check the air in their tires anyway. (Hint: What is "cold"?)
Which BTW since it is a safety system TPMS isn't going away, and it only turns on the warning lamp when a tire is significantly under and on some cars over inflated. (+/-25%) That means people should still be checking and setting the tire pressures on their cars on a regular basis and not just when the MIL comes on.
