Old Cars--When to call it quits
I would suspect that there is something else wrong which is causing these repeated failures.
Bad battery, voltage regulator, or an electrical drain problem?
Alternators usually go bad from having to supply an excessive amount of current thereby burning out an internal part of the alternator. I think there are diodes in them which can burn out.
If there is an electrical drain that runs the battery down, the alternator has to work too hard to recharge it.
Good luck
A lot of shops insist on rebuilding the customers old unit to insure quality or they will install a new (expensive) unit.
The assembly lines that rebuild these units often do a poor job, skip steps, and use inferior parts just to be able to offer a low price.
Hondas are great cars as far as reliability goes, as well as Toyota. However, judging all American cars on Chevys is unfair. Fords are also great cars. I had a 78 Merc that held on till last year when the tranny went, and I drive a 95 T-Bird with 150,000 miles and still running great. In fact, I didn't even get her til the odo was over 130,000. Woman who bought her new wanted something with less miles, and I got her for a song. Great car.
I've got a 1990 Ford Ranger It's a 2wd 2.3L 4cyl automatic. It has 132k on it now. )))ENGINE((( went south at 88k and was rebuilt by a very reputible engine rebuilder ~2 years ago. )))TRANNY((( went south 2x. Once at 55k then again at ~112k. Rebuilt 1st time under warranty. 2nd time by a very reputable local tranny only shop. Shop owner says a high % of these Ford automatics go south. 4.10 )))REAR END((( went south at 58k. Rebuilt under warranty. Fuel pump was replaced at 70k along with various other expensive modules, u-joints, brakes, tires, exhausts, and other misc components. In total )))I've((( spent about $5k in repairs over the last 80k miles. It gets about 17.5 to 20 mpg. It has been running fine lately.
Cosmetically speaking it's decent except for a dented passenger rear quarter that I won't bother to have fixed. It's got no rot. Interior is fine. Radio stinks. Heater is lousy. Last AC summer was still very cold.
Our family is growing again so we'll be up to by next summer. An extracab would be the next logical choice (we also have a van).
1.) When would you get rid of this truck??????
2.) And why then???
Thanks alot!
Marc
But now she's hurting. The engine always seems to start to overheat, then cools off. Needs rear struts @ about $400. Right rear pwr windows motor died, steering is starting to squeel and I am getting ugly and mysterious puddles inder the car.
Should I put it out of its misery????
But, sounds like you two have gotten MORE than your money's worth out of these vehicles! Be happy and move on!
dave
Having 211,000 miles on it, it finally exhausted its fourth or so battery. We've only had to replace the waterpump a couple of times and the starter. No other repairs! What a great car! This may be its last year. :-(
As a troubleshooting technique, you can test drive with the EGR valve disconnected in the closed position, the same as if you had no EGR system. Engine performance should be OK but exhaust emissions will probably not be satisfactory. This practical check will at least tell you if the EGR/EVRV/Computer are contributing to a driveability problem.
Also, where are you getting freon for six bux a can, Old Mexico? In this area, since the EPA put a ban on the stuff, it's been extremely expensive to get!
jridgway - before you scrap that Skyhawk, drop me a line (click on my name to get my email address) and I might be able to pick it up and use it for courier work until it dies. Just sold a 1989 Escort, had 352K on it, and the owner has moved safely to Tennessee with it.
Situation: Fix or Sell to Junkyard...decisions...decisions...
Major Problems
Area: Transmissions
Status: Dead?
Car behaviour?: Wont move, whether in [R] or [D]. Hold light blinked a week before tranny went kaput
Area: Right Controll Arm
Status: Bent
Car behaviour?: Wheels out of alignment. Probably needs a new arm
Area: Radiator Tank
Status: Worn - out
Car behaviour?: The plastic part is worn out, find a new plastic tank or whole
new radiator unit??
Area: Engine: internal/ external oil leak?
Status: (-10 degrees C)
Car behaviour?: Bluish/White smoke & clicking sound when cold when engine is cold, or blue smoke on hard accelleration
Area: Rock cover gasket?
Status: Loose? worn-out?
Car behaviour?: Car leaks oil like crazy, puts 1 litre of oil every 2-3 weeks!
Area: Compressor
Status: Siezed
Car Behaviour?: A/C is dead, no Power Steering since PS belt is connected to compressor.
Please advice on how much to expect in expense & labor costs. keep in mind I have a low budget for this.(I am in Toronto, Canada...any good (honest???) Mechanic?)
Body is EXCELLENT - no rust, dents, dings or anything, but the horror lies beneath the hood.
If it was a 98 7 series beemer, this would not ne a hard decision. But for a Ten year old car, I am wondering if this could turn out to be a black hole for my wallet
Maybe I do need a horse! lol!
I have a 1977 Mercedes 450SEL with 95,000 original miles (bought from a friend's mother 2 years ago.) The car was well taken care of but being a >20 years old car, it has a few problems.
1. AC compressor: seized
2. Leaking engine oil
3. Leaking transmission fluid
I am planning to move to another state and wondering if it is worth it to fix the car or should I cut my losses. The car itself probably doesn't worth much...donate to charity?
I would like to hear your thoughts.
Thanks in advance,
KD
The dealer who replaced the alternator condemned the engine, offering to install a used one for $3000. I checked with a motor rebuild shop who would rebuild for $4800 or replace with used for $3000. They both said oil paths had plugged, causing loss of oil to bearings and to the valve lifters.
This thing looks perfect and drives nice, although the mileage is certainly high and it doesn't owe me anything. Are there any "flushing" tricks that could free up those oil paths and get us a few more miles out of the thing?
Sorry, but new engine or new car are your only two options. When you say "used" engine do you mean rebuilt/reconditioned or yanked out of a wreck an plopped into your's? All of those terms (used, reconditioned, rebuilt) mean significantly different things. $3K sounds high for a used engine swap, but it is an Infinity. With a used engine you could be right back in the same boat before you know it. What is the car worth with a new or rebuilt engine? That should make the decision for you. Good luck.
First is it worth fixing this car ( interior and car appearance is very good) if it means a rebuilt engine needs to be installed?
Second what are the results of driving the car in this condition?
Please help me figure this one out.
So enjoy being in the good old US of A where you have the freedom to chose when to scrap you vehicle (almost).
On the other hand though, I've seen some rolling wrecks on the road where I live (Mich) that are probably a safety hazard not only to the the people in the car but everybody else around them also. Some states have mandatory inspections that get these hazardous clunkers off the road, which is probably a good idea, but I think it's a shame that legislation is neccessary to enforce what should be just plain old common sense.
The Japanese situation is curious. Since most cars in Japan accumulate very few miles by North American standards, scrapping after five years or so is particularly surprising. Does anyone have an idea of the typical mileage of cars scrapped in Japan?
Drive it until you need a significant repair(drivetrain or electrical failure) and enjoy life w/o a monthly car payment.
I bought my Grandma a used 89 Mazda 323 about 3 years ago. I hope it's half as reliable as your Mazda.
Are these symptoms recognizable by anyone?
How much will it cost to get fixed?
Thanks in advance for any advice, help that you can offer.
So, do I keep running it with normal maintenance, go for the reconditioned engine, or go for a new(er) vehicle? TIA.
but for an additional $350 to remove, repair and replace my clock--- IS IT WORTH IT? When is enough enough? Thousands into this car or $10,000 to a new Buick?
