Feels Like a Bus Around Tight Turns - 2007 Dodge Charger SRT8 Long-Term Road Test
Edmunds.com
Not surprisingly, our 2007 Dodge Charger SRT8 doesn't perform well on tight and twisting roads.
Thank you! It isn't fun being in a car that is good in corners and being stuck behind a car that isn't. Although in all fairness anymore a lot of people can't drive the cars they buy that can handle and end up taking the fun out of freeway on-ramps and back roads.
Couple side notes, speaking of suspensions, the old walk-through tech articles that Edmunds/InsideLine once did on a fairly regularly basis is missed. Also for the Charger, your choice in tires probably leaves a little to be desired if you like to hustle the big boat around tight switchbacks.
