2004 Saturn Vue has severe vibration at speeds approaching 55MPH
2004 Saturn Vue, V6 AWD with 138K miles. In the last 8 months I have had the struts rebuilt, all brake components replaced (everything), front axles replaced, anti-sway bar bushings replaced, front end alignment, replaced wheels and tires and front wheel bearings, replaced two broken motor mounts, removed defective main drive shaft, all to eliminate the vibration that begins at speeds approaching highway speeds.
The problem has not gone away but is much improved with the new axles and motor mounts. Sheering shaft was replaced 7 years ago.
The GM dealer refuses to look at it until I replace the drive shaft, which the car doesn't need to drive.
I have had it to suspension specialists and a dozen mechanics and we are all at a loss.
Answers
