Leather Seat Maintenance
i use the lexol 2 step method... i bought a 4 year old car with leather that looked/felt like it had never been treated... after 3 treatments spaced a week apart, the difference is pretty amazing... all it takes is about 1/2 hour once a week or so, and it's definitely worth the effort.
If the leather is "aniline dyed" then using
saddle soap or other cleaners will do much more
harm than good. A damp cloth is the best cleaner.
If that does not work try a mild dishwashing
DETERGENT ( NOT soap!!) Some stores sell cleaners
formulated for aniline leathers, but in my
experience they do not work much better than a damp cloth.
If the leather has been vegetable dyed (the way
a saddle is) then saddle soap (which is pure
glycerin) is best. But I have not seen this type
of leather used in an auto since the 1960's. (oops, I think I just gave away my age!)
the restorer is very thin and goes right into the leather to make it soft in seconds, they recommend leaving it overnight, which makes it even softer, and it doesnt leave a residue or sticky stuff after applying, its the best again.
detergent by definition is "something else" with surfactants added to it (i.e. detergent gasoline = normal gasoline + surfactants).
someone who is a chemist may want to correct me on this, but i believe the above to be true.
Good point! I'm no expert, but common sense tells me that a detergent formulated to cut grease and dissolve food is going to be harsh on leather.
Lexus recommends a weak solution of netutral detergent for wool (I read that as "Woolite"). My car is only 13 mos old, but so far, so good. I've been conditioning with Hide Food.
Ware. What model do you have? On my GS it is pretty easy to tell because the leather surfaces are pliable and the plastic is hard even though much of the plastic has a leather-like design. The seats will be leather except for the seatback on some (maybe all?) models. The steering wheel, but not the hub are leather as is the shift knob. The armrest cover is leather. The back seats and armrest are all leather. And there are leather inserts in the front doors (above the handles).
Leatherique, Lexol, or Zaino leather products are
better than the "Lexus" brand leather cleaner &
conditioner that is sold at Lexus dealerships. Has anyone tried the leather cleaner or conditioner that Lexus sells under their name and how did it work?. Are these other products better?
Also, my leather seats have more of a matte look right now since they're new. Any comments as to which leather conditioners will leave the leather with more of the original finish and not add a shiny/glossy appearance?
I use Leatherique on my Lexus and it leaves the leather looking natural - not shiny. Their Pristine cleaner can be used as often as you like. It wipes on and off quickly without adding any shine to the leather.
Their Rejuvenator Oil should be used a couple times a year to feed the leather. After letting the Rujevenator soak in for several hours or overnight, the cleaner is used to remove it and any dirt that is lifted up to the surface.
I would hope that any high quality leather treatment will do the job if used on a regular basis. I don't know of any scientific comparison tests between these products, so who really knows which product is significantly better, if any.
I haven't used other products, so I can't comment on those.
I got a car seat cover from LL Bean, but could not tell until it arrived that it is designed to work best with a folding back seat - which I do not have. I have been able to work the straps around the headrests and seat belt anchors well enough to get it to stay put. It has a padded seat and has worked quite well.
I also have used just a large bath towel on the seat. The dogs have been in this car individually probably about 15 or 20 times, and no problems so far.
Once I had to put the shepherd in the car without any seat cover, and no punctures occurred. He had a huge hot spot, took him to the vet, they put medication on it which he promptly got all over the leather seat on the way home. Zaino leather cleaner took it right off, no stains left at all. (And the truth is that when I got him home, I forgot about the stains and ended up letting them dry over night before I cleaned them up.)
Don't know if this is helpful, just thought I'd pass it on....
Call them if you can't find it. I believe it will work perfectly if you have fold down rear seats.
www.mossmotors.com/britishaccessories/carcare/chf.html.
Like I said, it's expensive, has to used every month, which is a pain, and I wouldn't believe the hype about it as posted by someone else on this board. It could be that someone works for the company or has a financial interest in it.
My dad was first to suggest it because he applies it every 6 months on his black leather and after 10 years, it looks ok, not perfect, but pretty good.
BTW, I bought the jar of Hide Food at a Mercedez dealer in the Bay Area for about $10.95. I had called around to BMW, Jag, MB, etc and BMW wanted $20 for the same size jar.
But I have not used Lexol.
Gold, which I did about a month ago for $10 or
so. The Sebring I purchased had 8,600 miles on
it so I immediately treated the leather by hand
rubbing the Meguires into the surface and let it
sit 10 minutes before wiping off. Do the town
hall viewers think that this product works as
good as Lexol, or should I dump the Meguires and
buy the Lexol?
Wayne
I don't know the specific answer to your question, perhaps someone else does.
Pat
I can't see how seat heaters can't hurt the seats to tell you the truth. Although I guess it's no worse than a car sitting in the hot sun all day.
Wayne
Good Luck!
I bought it used after 4 years old and I don't think the original owner ever treat the leather.
good luck.
-Chris
Ed
edandty@msn.com
Can the gouge be kept from growing if the leather is properly conditioned, or is it a tear waiting to happen?
As far as conditioning goes, it sounds like the Lexol products might do the trick for me.
I am thinking correctly?
Tom T.
I recently found that the driver's side door
(above the armreast) developed a redish-
brown discoloration. I used the Lexus leather
conditioner and cleaner, but they helped only
slightly. My only guess where it came from: my
Andrew Marc leather jacket sleeve. As far as
cleaning the leather, I'm sure I can take it back
to Lexus and they'll restore the color. But how
can I prevent and fix this problem myself in the
future? Any ideas?
I doubt I can repair this myself, but am very open to suggestions.
If not, do you have any idea what I'm in for at an upholstery shop? Can the single panel be replaced? Should the entire seat be reupholstered -- nothing else is a problem.
Thanks, I'd like to have a feel for the project before I get to an upholsterer.
Take care.
Joe W.
Good luck!
Pat
I also used the Z10 on the vinyl dash and side panels. It does quite well there as well. Good stuff.
