2012 Honda CR-V Long-Term Road Test
Edmunds.com
We took the 2012 Honda CR-V into the dealer for its 20,000-mile service. The price wasn't bad, and the efficiency of the staff was even better.
(1) [i]I know that 0W20 synthetic is required for the CR-V[/i]
and
(2) [i]I picked up the CR-V about an hour later and was pleased to find the total bill did indeed reflect a discount: It was $139.07 with tax. That's right in line with the Edmunds.com Maintenance Calculator's suggestion that you should pay $145 for a 20,000-mile service on a 2012 Honda CR-V if you live in the 90404 zip code.[/i]
(1) full syn is wrong as crv is listed per manual @ 0w-20 which can be a blend or full syn
(2) i always check dealer sites for coupons so next time check dealer site for coupons "Includes: Change oil up to 5 qts.- Install Honda genuine oil filter - Multi-point inspection - Vehicles with 0/20 grade are $59.95" http://www.hondaofsantamonica.com/specials/service.htm (Multi-point inspection includes all that hose n brake checking stuff)
59.95+tax (59.95+(59.95x.095))=65.65
crv in the air doing oil so rotating tires=?
edmunds payed 139.07
ipad & service advisor=fancy and less money in your pocket
