Visitor Agreement.
For hard starts, have fuel pressure checked. If over spec, suspect a leaking fuel pressure regulator.
For misfire, replace spark plug wires if original (use ACDelco only), check distributor cap for oxidized terminals and carbon tracking, rotor for burned contact tip.
P401- EGR flow insufficient
I reset the trouble code on the computer. The vehicle has been driven 4 days and the code has not reappeared yet. Could this be something as simple as removing the EGR and cleaning?
Also, unrelated - but what is the normal output voltage range for 02 sensors? My scan tool software lit up a red background around my bank1 o2 sensor reading when it was in the .8 voltage range. Is normal +/- 0.5 volt?
Circuit Description
The PCM tests the EGR system during deceleration by momentarily commanding the EGR valve to open while monitoring the Manifold Absolute Pressure (MAP) sensor signal. When the EGR valve is opened, the PCM should see a proportional increase in MAP. If the expected increase in MAP is not seen, the PCM notes the amount of error that was detected and adjusts an internal fail counter towards a fail threshold level. When the fail counter exceeds the fail threshold level, the PCM will set DTC P0401. The number of test samples required to accomplish this may vary according to the amount of detected flow error.
Use this routine:
- Remove the EGR valve.
- Visually and physically inspect the following items:
Pintle, valve passages and the adapter for excessive deposits or any kind of a restriction.
EGR valve gasket and pipes for leaks. Clean or replace EGR system components as necessary.
- Remove the EGR inlet and outlet pipes from the exhaust manifold and the intake manifold.
- Inspect the manifold EGR ports and the EGR inlet and outlet pipes for a blockage caused by excessive deposits, casting flashing or other damage.
Upstream O2 sensor voltage should vary fairly rapidly between about 200mV and 800mV. Downstream sensors should hold fairly steady around 500mV.
nothing looked loose, and i didn't see any shorted wires but i didn't pull down the sheath to check all the way down. but i jiggled the wires anyway.
these wires are on the passenger side of the car. the air filter housing is on the driver's side, so the wires don't run anywhere near it.
i still don't know why opening the air filter unit fixed the problem. and i still don't know why the code pops up only when i have the A/C on. but i did notice that near the air filter housing are the acceleration and cruise control cables. i jiggled (pulled/pushed) them as well.
anyway, no more problems with the check engine light coming on. i drove 200miles with the a/c in 90+ degree heat w/o a problem.
now how do i remove the ocv filter to get it cleaned/replaced? i have no room for the rachet to move. the alternator is in the way. if i remove the alternator, then i also have to remove the fan belt. how easy is it to put back the fan belt on a 2002 prizm if you are parked on the street?
THX
if you have similar concerns, it should fully depend on whether you have plenty of room to get to your belt tensioner, and plenty of swing area to tweak it to limit and slip the belt on. notice that old belts are stretched, and that it's thus a whole lot easier to get the old belt off than to get the same belt back on, and a new one is harder still.
Why did you replace the O2 sensor??
Let me guess, because someone told you that when the light comes on, it is always the O2 sensor.
Well, I guess you found out the hard way, that it is rarely the O2 sensor.
Anyway, to your problem.....
First, clear the trouble codes, by disconnecting the battery for at least 30 seconds, then roadtest and see if the light returns. If it does, then retrieve the trouble codes. This page gives the procedure.
Then on the same page, scroll down to your engine. In your case, I am pretty sure it is 86-88 5.0L Carburetor, VIN H. That link will take you to the codes list.
Come back and let us know what codes you got.
PS The test system worked as advertised but the 12 pin DLC was a little different. The entire top row had pins and the bottom row had none at all???
The remainder of the pins are for various other applications that may not be used on your vehicle.
The code 12 is normal and nothing that we can use. It will always show up. What you need to do is to drive the vehicle until the light comes on. While the light is still on, find somewhere safe to pull over and run the test. Print out the page with the test on it and bring it with you. (It's ok, it is mine.)
Since it is coming on at highway speeds, then more than likely, it is an EGR problem, but without the codes, we cannot be certain.
One of the reasons that I say it may be an EGR problem is because one of the symptoms of an EGR problem is the light coming on at higher, sustained rpms and long pulls, such as climbing a long hill.
If you are mechanically inclined, you can purchase an EGR gasket (about $4) and pull the EGR and check to see how carbon plugged it is. Clean all of the carbon out of it and the passage in the manifold (A heavy guitar string on a drill motor works real good for running thru the manifold passage to open up the port). Then re-install the EGR and roadtest again. If the light doesn't come on, you know that was the problem.
Cost of the fix to you would be a couple hours time and under $10 for parts. If it isn't the fix, then you are out a little time and the EGR gasket needed replacing and inspected anyway. : )
With the age of the vehicle, it is very common.
CODE 12, NO DISTRIBUTOR REFERENCE PULSES
CIRCUIT DESCRIPTION
Code 12 means the ECM is "ON" and sees no reference pulse from the distributor. This is a normal code with the ignition "ON" and engine not running,and is used for the verification of ECM operation during the "Diagnostic Circuit Check". Code 12 is not stored and will only flash when the fault is present. With the engine running, Code 12 could mean an open or ground in the distributor reference circuit. Code 41 will appear with Code 12 if the engine is running with no distributor reference signal. If the problem clears, Code 41 will store.
You will need to shut it off, then turn the key on and check the codes.
I checked and the gaskets you need are Fel-pro 70950 and 2 are required.
They should run about $3 each.
After looking, you may have trouble getting the EGR out without removing the carberator. If you cannot pull it without removing the carb, then you will need a carberator gasket too, but this is an area where you really should have someone do it, if the carb needs to be removed. Fuel will be present and that is a dangerous thing.
I wouldn't change any parts right now.
You can't be sure that the EGR is the problem, so you would only be throwing money away.
Here is some info to help. It is a pdf file and requires Adobe Acrobat reader.
But as I said, you need the trouble code of what is turning on the light. That will help determine what the problem is and work toward repairing it.
One thing you might try, if there is an AutoZone near you, they can hook up to it with a scanner and maybe they can pull some codes from it.
Following is a long saga of dealing with P0442 code on a 2000-Saturn
SL2:
Saturn has yet to fix this vehicle with reliability or credibility;
the manufacturer doesn't seem to have the answer, either. Problem
started 2 days after 3-year warranty was up: Last visit, car was in
shop for three days. Car has never been to an outside mechanic.
Notice repeat part replacements on this low mileage car. Come
4/1/2005 this car will not pass inspection in New York State. In
fairness, Saturn has not charged me, but I can't even get another
dealer to take this car as a trade-in.
Any suggestions on what Saturn mechanics failed to do? They claim car
passes pressure tests and smoke tests -- that the car is mechanically
sound -- that there is no leak.
George
Date Miles Part and Part serial number and job
>04-Nov-2002 10622 PCM Engine Coolant Temperature Sensor 21025106 Replace
>04-Nov-2002 10622 Connector 12117087 Repair ALDL/DLC/SES
>02-Jun-2003 12875 State Inspecrion
>10-Jun-2003 12996 None No Repair
>17-Jun-2003 13113 Seal-F/PM 21008100 Replace Fuel Pump Seal
>07-Jul-2003 13339 Solenoid, Evap. Emiss. Cannister Purge 10293954 Replaced Valve ASM
>07-Jul-2003 13339 Solenoid, Evap. Emiss. Cannister Purge 21007370 Replaced Tank ASM
>23-Jul-2003 13509 Fuel Vapor Pressure Sensor 16238399 Replaced
>11-Aug-2003 13773 Solenoid, Evap. Rmiss. Cannister Purge 21008461 Replaced Solenoid
>16-Sep-2003 14242 PCM Engine Coolant Temperature Sensor 21025106 Replace
>21-Oct-2003 14605 Tank ASM 21007370 Replace Fuel Tank
>21-Oct-2003 14605 Cannister 17098073 Replace Fuel Vapor Cannister
>21-Oct-2003 14605 Valve ASM 10293954 Replace Vaklve for Evap. Emiss Cannister Vent Solenoid
>21-Oct-2003 14605 Pump Kit 21015152 Replace in tank Fuel Pump
>06-Jan-2004 15467 Fuel Tank Filler Neck 21008388 Replace fuel tank filler neck
>04-May-2004 16672 Engine Control Module (PCM/ECM) 21025128 Replace Computer
>14-Jun-2004 17217 PCM Engine Coolant Temperature Sensor 21025106 Replace
>14-Jun-2004 17217 Fuel Tank Cap 22660002 Replace
>27-Jul-2004 17567 Fuel Vapor Pressure Sensor 16238399 Replace
// delayed // just had a brainstorm of sorts. what does a voltage read on the input to the computer module show? if the sensor voltage is in range, you could have a one-channel a/d chip failure on the computer. also I would use a toothpick to apply some Caig De-Ox-It to the contacts of the computer input connector, and pull and replace that connector several times, in case this is an oxidized contact issue. De-Ox-It is availiable at specialized electronics parts suppliers, by internet order you can get it at www.tubesandmore.com . fantastic stuff.
I bought a 2003 Honda Civic Ex coupe, 2 Door , 5 Speed Manual with 7000 Miles on it.
The car had its first service at 4500 Miles. Now it has around 8100 Miles. The dealer said the next service is due after 10,000 miles.
But,Yesterday I got the maintenance required Light.I checked the fuel tank cap it is fine(basic trouble shooting).
Can any one tell me what could be the problem or give me more trouble shooting tips?
I Still have warrenty on it. Can you give me suggestions , so that I can ask them to change the parts if required.
Smith.
If the light is out, then the problem has reset itself. It will be alright to run without any problems, provide the light stays out.
A solid light on means that there is an emissions problem somewhere. A blinking check engine light means that there is a catastrophic failure and continuing to run the vehicle will result in damage to the engine or drivetrain.
That being said, you should be ok to run the vehicle. If the light comes on again, a stop at an AutoZone and they can pull the trouble codes. Once you have the trouble codes, we can help you decipher them to find the cause. Don't let them sell you anything.
fastpaul,
What was the trouble code number that the mechanic got?
Did he replace the "heat sensor", which I am assuming to be the temp or cold start sensor, with an OEM sensor??
If he didn't, that is most likely your problem.
The engine uses a temp sensor for cold starts, to keep it running when cold. If the sensor is not OEM, then it will send an erroneous signal to the PCM and it will send an incorrect fuel mixture.
If the system works like mine on a 98 LeSabre -- it checks for leakage in the fuel tank system by drawing a vacuum or pressuring slightly and then testing how long that change in pressure lasts. It only does this when the engine is between two temperatures when started. As in drive 3 miles. Stop for coffee. Restart. I think the temp had to be 130 degrees but below a certain temp.
When that happened and you restarted the engine the light probably was out within a minute. That's what happened with mine when the cap was loose.
Why would you go to a muffler shop for brakes and a battery??
That's like going to a tranny shop for a tune up.
Without knowing what the troublecodes are, it would be tough to even guess if it could be something they did or a coincidence.
Is there an AutoZone near you? If there is, they may be able to pull the troublecodes and tell you what numbers they are. Don't let them sell you anything, just get the codes. ; )
Once we know what the troublecodes are, then we can determine if they are related to anything that was done. Probably not, but won't know until codes are retrieved.
The best thing I can tell you is to check the fuel cap (just a common starting point), make sure the gasket is good and intact, check that all vacuum hoses and connections are good, then clear the trouble codes, road test and re-check teh troublecodes. If the code returns, then you will need the diagnostic chart and a scantool to diagnose the problem.
Purge solenoid valve malfunction
Cannister drain valve malfunction
Tank pressure control valve malfunction
Charcoal cannister malfunction
clogged air filter
Evaporative gas valve clogged
Evaporative hose damaged
Fuel tank pressure sensor malfunction
ECT (Engine coolant Temp) sensor malfunction
VSS (vehicle speed sensor) malfunction
open or short in wiring harness
poor connection in EVAP system.
It's funny that this all happened right AFTER I put a new tank of gas into the car from the same station that I have been getting gas for for the past 5 years. Just my luck I guess...LOL.
Does the atmospheric sensor sound like BS? I've never heard of it before. Also, we asked that they leave us the old parts, but they conveniently "forgot".
Any other ideas what may be causing this problem?
I have got exactly the same issue (P0171) on my 2000 toyota corolla with 53K miles on it. I have been told to replace the oxygen sensors, but I am not sure if that is the root cause of the problem. Can you please let me know if this problem is fixed on your car and what did u do to get it totally fixed. (I usually fill gas from Chevron but the check engine light came after I filled the gas from some gas station at a rest area on highway)
Would really appreciate if I can get help on this.
Don't believe everything you're told. The O2 sensor is reporting a lean fuel condition. Start by checking for any cracked, broken or disconnected vacuum hoses. Also check the ducting to the throttle body for any damage. If all's ok, have the fuel pressure checked.
THIS IS MY SORRY TALE:
NO CHECK ENGINE OR CODES FROM ECU.
Started to bog at low rpm. Replaced fuel pump; cold start injector, diaphram are ok. Replaced ALL SIX fuel injectors (They were cracked and leaking), plugs, plug wires, dist cap, rotor.
Is now burning rich; runs good when cold, then black smoke out tailpipe when it warms up and cylinders 5&6 periodically misfire. Plugs in 1-4 cyliners are black, but not oily.
Have put $3,500 into it. Mechanic is going to check sensors and ecu with ohm meter. He seems in over his head. HELP!
Dealer diagonsed the following: P0135,P013 & P0133
Two Oxy sensors[$225 each] and Catafold converter[looks like catalytic converter]-$625.
Any suggestions/guidance on taking a second opinion from a different dealer/auto shop.
Please advise.
I have to assume it is a diesel, because the only engine that shows a trouble code P0673 is the diesel and that trouble code is a glow plug cylinder #3 malfunction.Check for an open or shorted circuit to the #3 cylinder glow plug and test the glow plug.
I just took it to the dealer and now this happens. The last 2 times I took it to the dealer, other things have broken too, including the air conditioning exploding and Honda having to pay for the $4000 damage it caused, as well as a leak in some hose. Is this just a coincidence or is the dealer messing up my car so they'll make more money!PLEASE EMAIL ME bunnywillgetyou@yahoo.com
I don't want to blow up in my car!
