How Tall is Mount Everest In Yards? - 2015 Volkswagen Golf GTI Long-Term Road Test
edited September 2015 in Volkswagen
imageHow Tall is Mount Everest In Yards? - 2015 Volkswagen Golf GTI Long-Term Road Test
On the plus side, the navigation system in our 2015 Volkswagen Golf GTI displays elevation on screen. But it earns an F for math.
  • ebeaudoinebeaudoin Member Posts: 509
    Very odd.
  • nomercy346nomercy346 Member Posts: 69
    First it's emissions, now they even lie to you about your elevation...
  • Great observation, Dan!
  • vvkvvk Member Posts: 196
    The whole thing is lunacy. There shouldn't need to be a conversion at all. The whole humanity should be thinking in meters/kilos/Celsius and that's the end of it.
  • boffboff Member Posts: 91
    Don't forget the parsec.
  • bc1960bc1960 Member Posts: 171
    It looks like yd are being used because they designer of the GPS (which may not be VW at all) didn't want to make the text box bigger just to accommodate the handful of countries that use ft for altitude. And while the coincidence of m and yd is suspicious, I often find a large discrepancy between GPS altitude and roadside markers, because you need more satellites to get accurate altitude than location, the datum used may be different, and the marker may refer to a nearby high spot and not that precise location. Mazda doesn't even bother to give me altitude on its current GPS system, just one of its many deficiencies
