Adjust Idle 2004 Pacifica
We have a 2004 Chrysler Pacifica that we recently purchased.
It idles high and we want to adjust the idle down some.
I've been searching and unable to find where and how to adjust the idle.
Any direction would be much appreciated.
Being a new vehicle to us, we did an oil change. The engine light came on recently and error code indicating evap issue. We replaced purge valve and gas cap.
Most recently we replaced spark plugs and boots, after that the high idle started. He's going to take a look to see if there's anything obvious standing out where he reassembled everything.
Question: If there is no engine light on, and we scan for trouble codes, will it give a trouble code?
And that's right, the idle speed is not adjustable.
Thank you so much for your feedback, we so appreciate you kindness and time troubleshooting.
1) Under the tire well above the dog bone for suspension is a Negative or ground cable bolted to the transmission this sometimes comes loose and will prevent your car from starting or even turning over.. There is also a harness that passes over this bolt which will rub out on the back side in time.. This will cause problems in the egr, i.a.c., t.p.s and Ats.... Fix the wire fix the problem
2) if you open your hood under your battery not directly but down low youll see your solenoid packs and other transmission sensors follow these to the thicker wire harness down to wear it almost touches the frame and meets other wire harnesses... The back side of this "crossroad" rubs up against some kind of flange on the transmission with bolt holes in it.. This is the problem with transmission issues in the 2004 Chrysler Pacifica 3.5l.. Fix the wire fix the problem!!! I spent alot of money on parts to figure out this simple easy cheap fix.. Make sure to reinforce protection in the back of theose wires during fix.. Hope i save dyou some
