2003 Chevy Impala tire pressure
Hello my car has 225/60R16 tires in the front that the recommended tire pressure for the is 30 psi according to the sticker in the trunk
Then in the back I have 225/50R16 now I keep these at 30psi aswell but I do not know if it is the right pressure for these tires. is there some way to calculate the required pressure?
Best Answer
capriracer
Member Posts: 907
Yes, there is a way to calculate the tire pressure, but you need to have access to the tire load tables, which are copyrighted and not allowed to be published except by permission. I have a copy and I'll do the math for you:
The rear tires need to be at 35 psi.5
Answers
My question is, what could be causing the air leak on a nearly brand new set of tires? I have to refill that tire about every 2-3 weeks. Also, my husband said that the pressure should be between 40 and 45 psi. Sure enough, when it falls to around 39 psi, the warning light comes on for the tires. Help?
45 psi is over the spec, but if you prefer a stiffer ride and don't mind the possibility of uneven tire wear, then that's your call.
The tire pressure monitor can't tell you which tire is deflating (although it sounds like you know) and it will only detect a pressure differentiation. It doesn't get set to a specific tire pressure. If all your tires were inflated to 30 psi or 50 psi, and one drops a few lbs., the same thing would happen.
I suspect you must have a rim leak of some sort--on some alloy wheels, the wheels themselves can leak--right through the metal, not the rim. The cast metal becomes porous as it ages. GM cars are known to do this, too.
This can generally be repaired with sealant.
You can look up the values here - Metric Tire Inflation Chart
