For scan tools, try here:
http://www.batauto.com/links.html
Scroll down to Scanners and Diagnostic Tools. Auto Xray are recommended for versatility/price.
The more I read this manual, the stupider(?) I feel.
I couldn't find any vacuum leak. Pls tell me what I should do. Clean the Idel Air Control Valve? Replace O2 sensor? I feel frustrated and desperate. Is there any connection between the CEL and the idle problem? I don't understand why they only occur occasionally. By the way, the idle speed is rather low, only 300-350 rpm from what I read from the tach. So whenever it drops, it drops almost to zero. The dealer told me the idle speed was set at manufacturing and couldn't be adjusted. Another quite old problem of the car is that some fan seems not working when at low speed: if I drive along a slow street with many traffic light, the engine temp will rise way above normal. It will cool down after I speed up. But the CEL is a quite recent problem, shouldn't be caused by the fan relay.
Sorry for the long post. Any suggestion is appreciated!
I can just see myself standing there holding the two probes of a voltmeter whilst the entire wiring harness is frying.LOL
http://www.honeyijusthavetohavethistoolitwillpayforitselfinnotimeandlifewillbewonderful.com
LOL
Once you have a scanner, there are 2 ways to proceed.
One is to purchase a cd from Chiltons, Total car care CD around $20
or for $20 a year, you can get a subscription to Alldata's DIY on-line manual Alldata DIY
I don't know about the Chilton's Total car care CD, but I do know that the Alldata DIY has flowcharts for trouble code diagnostics.
Opatience, I have the Mazda service manual with all the flow charts and DTC troubleshooting info. Just need to make the leap for the scanner.
There are alot of scanners out there, right now we are putting a relatively inexpensive PC based scanner to the test. It runs around $170 and is set up for all major manufacturers. Don't know how well it is going to work, but I thikn it will be worht checking out. The scanner is available at CarCode Scanner A discount is available for that scanner,but I prefer not to post it here.
Professional courtesy, you know.
ddraves461,
You need to have a scanner put on the truck that has a moniter mode and moniter the vehicle while it is operating.
Next time the check engine light comes on, pull the trouble codes yourself.
Here are 2 web pages that give the info to pull the codes. Ford code info and Dalidesign Ford code info
The codes may be there if you are able to pull them right away.
One thing though, have you replaced the fuel filter and checked the exhaust flow?
the PC based scanners use a laptop or desktop and the cable that plugs into the vehicle goes to a serial port on the PC(or laptop).And it pulls the info from the vehicle.
The laptop is by far the best to use, because you can road test the vehicle and use the laptop to moniter while it is operating.
If you are interested in the scanner and think it is something you want to persue, e-mail me and I will give you some discount info. I am not endorsing it yet, as we are still testing it and I haven't heard the results on it.
Checking for that valve I discovered that my car HAS NO Charcoal Evaporative Fuel Canister although I found it in the book at all model years (95,96,97,98) in two different places. Could be the third place? Could the ex-owner have removed it and the car parameters are still in range? Can you 0patience, alcan or somebody else please help me with this issue? Thank you in advance.
Has anyone had experience with aftermarket O2 sensors? Are there fit problems, do they last as long?
I have a 97 Ford E-350 Super Duty (Van chassis)V10 with 83,000 miles, and the "check engine" light has been coming on for a while, now. The OBDII gave the code "Bank One Sensor 2, Oxygen Sensor" per the mechanic. I thought, oh, that's easy... then called around for pricing to buy all 3 factory Motorcraft O2 sensors. I guess I was not prepared to find the parts alone cost nearly $300. I can save a significant amount by buying Bosch from Napa. I am hoping to find a discount source for the Ford parts, or learn from other's experience with the Bosch replacements.
Anyway, I got the code from the first time which was a code 44, lean mixture or something to that effect.
I am looking for a troubleshooting flow chart. I didn't see it in my Haynes manual for the car. I just returned from my library and Chiltons doesn't have it either.
Does anyone know a good online exhaustive reference for that type of information? Or can someone post the troubleshooting tree for this code. I don't want to just throw parts at it.
But if I need to start pitching, I'm thinking:
1. Vacuum Leak/Intake leak.
2. MAF dirty
3. Low voltages
4. Bad O2 sensor
The light goes out when the vehicle gets moving.
Any thoughts, help etc. The vehicle drives well, but trips this light during extended idling.
TIA
TB
I Just bought a 1988 Acura Legend as a Second car. It has 156K miles and looked to be in very good condition. After driving it for two weeks, its check engine light came on. When I turn the car off and then back on again the light goes off for a couple of days. After loosing a couple of night sleep, I visited this page yesterday and got some useful information. Thanks to the web site at http://www.batauto.com/acura.html I was able to retrieve the code (I think). When I turn the key on the and look at the Engine Control Units LED under the front passenger seat. It gives one long flash then a pause and then eight quick flashes. Now if I do not turn they key off, it keeps giving eight quick flashes separated by a pause. I am assuming that it the code 8, however, there is no code 8 listed for Legend at the above listed site (they have provided a list of codes for Integras and Legends). There is a code 8 listed for Integra which is TDC sensor or circuit. What the heck is TDC? If someone has access to Acura Trouble Code, could they please tell me if code 8 means the same thing for Legend and translate it in plain English for me. Acura dealer is asking for $90 just to retrieve the code. Who know where they’ll go from there… Please help!
http://www.batauto.com/cgi-bin/Forum/db_TalkToMeV2.cgi?forum_name=imports
1997 Mazda protege 60000 miles.
The check engine light is on and got the error
codes by a dealer.
P1170
P0176
P0505
Anyo suggestion?
Check for vacuum leaks or open or short in the Idle Air control motor circuit.
P1170 - Front heated Oxygen Sensor - inversion
Causes Low fuel
Oxygen sensor or circuit faulty
Intake, ignition or fuel system malfunction.
I would check for a vacuum leak as both codes can be tripped by a vacuum leak.
The P0176, I do not find for your vehicle.
hear some noise under the car. The frequency is
2-3Hz(maybe) and doesn't change even if I push
the gas pedal. I can even fell the shaking when
my foot is on the brake. If I get off the car,
I can hear the noise like air leaking under the
car.
"the P017x range, which deals with fuel trim"
Got from "MAZDA PROTEGE PROBLEMS"
The dealer said it's not easy to find out the problem and they need 3 hours labor. If they can REALLY find out the problem and fix it, that will be fine. But I heared some terrible story about the CEL problem, and I'm afraid it's just a beginning......
Anyway, last week, the problem grew further, while driving on a local road here, the rpm shot up to more than 4000 and the Jeep dint want to speed up (or maintain speed). It was like pressing the gas pedal while pressing the clutch on a manual shift car. The Check Engine light lit up. I shut off the car and then started it again. The CEL din't go, but I was somehow able to make it back home. The following day, I took it to a dealership here. They checked and said that the Speed Sensor was faulty and that they replaced it. I took the jeep, drove it for a couple of days, was all right. But again, yesterday, the same problem occured and the CEL came on. This time I was on the freeway when the jeep suddenly refused to accelerate.
It has been almost 10-11 months since I started having this problem, and I've lost track of how many times I have had this looked by the dealerships, I'm guessing 10-11 on this too. I have always used premium gas, din't mind paying a little more to keep my Jeep running great. But guess I'm not that lucky. I checked the code this time myself, it is 15, which means Speed Sensor problem (same). I am quite fed up with this. Can somebody tell me what exactly is the problem, and why is that all these dealerships are not fixing the problem once for all. Or are they not competent enough to get to the root cause of the problem?
Also, is there a chance that this behavior is caused b'coz I'm using 92/93 octane gas (premium)? Can higher octane gas cause damage to the engine/other parts? I guess not, but I thought I'll still ask.
Any feedback would be helpful and greatly appreciated. Thanks.
Thank GOD this was the last year they made this car to spare potential Corsica buyers in the future.
70K mile just showed up today. Does anyone have
any idea what is the cause and where can I
retrieve the code besede dealer. Also how can I
reset the check engine light. Appreciate your
input.
The connector is located under the dash on the passenger side. I have no idea what the service connector consists of, but with it connected, the check engine light will flash codes. This method is extremely crude and not reliable at all. It was designed as a method to check basic things.
Best thing is to have the codes scanned with a scanner.
anyone who offers a guess at what why the check engine light is on, is GUESSING, plain and simple, with dozens of possibilitie, any of them could be the cause.
how do I reset the light?
Post back with the engine code (8th digit in the VIN). Makes a difference in type of EGR and diagnosis. Disconnect negative battery cable for minimum 10 minutes to delete trouble codes and turn of CEL.
