25,000-Mile Update - 2015 Ford F-150 Long-Term Road Test
Our 2015 Ford F-150 doesn't sit idle very often. We've covered 25,000 miles in 10 months already, with no issues to report.
Again, I would look closely at the brand badge because I can't believe tis isn't a Toyota....sort of like our 2015 Toyota Corolla that was given to us as a rental this week while our rear-ended Ford Explorer is getting fixed. In one week this "hallmark of reliability" has had intermittent starting problems, air leaks through the passenger door handle into the cabin, the trunk takes two slams to shut, and a check engine light came on today when my wife accidentally shifted into neutral (from drive to neutral and back) while driving home. Oh, and that new engine sounds like a hummingbird passing gas. Do people really buy this things!?!?
I've got a 2015 Reg. Cab, 2wd, short bed, with the 2.7 Ecoboost, with only a 25 pound, soft-top tonneau, so I've got a truck with an empty weight of less than 4200 pounds. I can tool around in that truck and even accelerate at an acceptable clip with just barely touching the accelerator and staying under 2000 RPM most of the time, which is much like the previous Ford 4.6 V8 or a small diesel like the Ecodiesel, except that an F150, unlike a Ram, can be had for much, much less than $38K, as is mandated when opting for a Ram diesel; In fact, as an owner of an F150 with that previous 4.6 V8, the Ecoboost torque comes just a little lower than the gas V8. So everyone who hasn't thought this out, please think through what you're saying. If a pickup powered by an engine (any sized engine)can be easily propelled by that engine staying in a low RPM status while doing it's job, it is not being overly stressed; will not prematurely wear out, as compared to a comparably-powered V8; but can achieve better mpg when used and driven that way most of the time if it is smaller displacement and is not sucking in gobs of fuel, which is the case in this truck, with this engine, when it's being conservatively-driven in a light version configuration. My average mpg so far is 23.
Now it is possible that there is something in Ford's design that will make it a bad engine, but if that does come out to be true, it will not be the concept of adding low-end torque and better possible mpg through direct injection and turbo charging.
